Ever turn on your computer and try to connect to the internet? Ever see all the many SSIDs in your neighborhood listed in your wireless radar or your "Windows Wireless Connection". Then you'd scroll down to double click on your SSID so that you can connect to the internet. Imagine doing this everytime you have to connect to the internet. Wouldn't that be annoying?
The Objective
The objective of this Tip/How-To is to have you turn on your computer and connect to the internet automatically via your SSID (Wireless Network Name). Hence, you wouldn't need to manually find your SSID everytime you need to connect to the internet.
Pre-requisites or Must haves for this Tip to work
- A computer with a wireless adapter
- A wireless router
- An active internet service
- This tip is designed for Windows XP. I will post one up for Windows Vista and Windows 7.
- This tip is designed to work with Wireless Networks (SSID) that do not have any passwords or encryption.
Active Tip Dictionary (throughout this TIP)
SSID is the technical term for your broadcasted network name.
This is basically what you will see listed in your WIRELESS NETWORK CONNECTIONS manager.
To make your computer connect automatically to the internet via your SSID, we will need to manually tell your computer to connect to your SSID and then we will need to save this setting so that your computer will automatically connect to your SSID everytime you turn on your computer.Let's Begin.Start your computer by turning it on.
Click on your Start Button.
Move your mouse over to
Control Panel and then left click on it.
Double click on the
Network Connections icon.
Double click on
Wireless Connection. Now in the picture above you see Wireless Connection 3 but on your screen you should see Wireless Connection.
Now click on
Properties.
Click on the
Wireless Networks Tab.
Now scroll up and down under
Preferred networks until you find your Wireless Network Name (SSID). For me, it's called
linksys therefore I will select linksys.
Now click on
Properties.
Now click on the
Connection tab.
Under
Automatic connection,
click to check "Connect when this network is in range". This will tell your computer to connect automatically to your Wireless Network Name (SSID).
Click OK to save this setting.
Click OK again to get out of the Properties window.
Click OK again to get out of the Wireless Connections window.
Then click Close to close out of the Wireless Connections window.
And there you have it, you have setup to automatically connect to your Wireless Network (SSID) everytime you turn on your computer.
Now restart your computer and give it a few seconds, and voila, you are automatically connecting to your Wireless Network (SSID). Now you can surf the internet. You can set this on all your computers at home that have a wireless card.
Remember to give me a good rating and vote for me. If you require further tips and tricks, feel free to contact me through the contact box. I will post up your tip.
