Master
- Posted on Apr 05, 2010
Re: The door will not close. It appears that the lock is...
Check for obstructions, Check the door
latch the latch may have moved into its housing,use a screw and position the door latch properly free from any obstruction,then try closing the door again..if not then you may need to replace the door.hope this helps pls do let meknow
