Sanyo Xacti VPC-CG9 Digital Camera Logo
RW Starratt Posted on Apr 05, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Blurry enlargements after i download the photos, even if they are taken at a high resolution, i cannot enlarge them to even 100% without blurring the image photos from our other cameras, even at a low resolution will enlarge clearer
Paul Reed
Level 2:
Sergeant:
  • Expert 379 Answers
  • Posted on Apr 05, 2010
Paul  Reed
Expert
Level 2:
Sergeant:
Answers
379
Questions
Helped
112399
Points
683
I suggest altering the settings a little and if that doesn't work try using a different software to enlarge images. Such as windows photo gallery. That's not too good for enlarging just good for keeping the quality up if that isn't good enough try using a free trial of photo shop.
Hope I helped Dr Red
August Brown
Level 3:
Genius:
  • Sanyo Master 1,652 Answers
  • Posted on Apr 22, 2022
August Brown
Sanyo Master
Level 3:
Genius:
Answers
1652
Questions
0
Helped
352049
Points
5096
To enlarge photo, you can try Leawo Photo Enlarger. Below are detailed steps.
Step 1: Launch the software after installation, and then enter Photo Enlarger module.
Step 2: Click the Add Photo Folder or Add Photo button on the main interface of Leawo Photo Enlarger to import source image folder or images.
Step 3: After importing, if you want to increase resolution of a batch of images at once, click the Output button at the bottom right, and make batch output settings.
Step 4: If you want to enlarge photos one by one, double-click on a loaded photo to enter the workbench, where you can set scaling ratio, and effect like denoise, deblur, brightness, etc. for a single resized image.
Mental Breakdown
Level 1:
Problem Solver:
  • Contributor 12 Answers
  • Posted on Apr 30, 2014
Mental Breakdown
Contributor
Level 1:
Problem Solver:
Answers
12
Questions
0
Helped
6580
Points
26
Please be aware that softness will increase with higher resolution (or taking pictures with a high focal number for the same reason).
Higher resolution doesn't automatically result in a sharper picture. It just enable you to catch more detail but makes weaknesses in gear or techniques more obvious...
Dave King
Level 3:
  • Master 1,606 Answers
Dave King
Master
Level 3:
Answers
1606
Questions
0
Helped
503474
Points
4860
Check to see that you have the camera set to high resolution AND high detail. If the high detail settings is left off the pictures will be big but not very sharp.
Enlarging picture makes them blurry
Digital pictures have a set pixel density (resolution) when they are taken This can be adjusted on some cameras and on others it cannot. IF you are using a camera with a low rating or you have your camera set that way (more detailed picture with higher settings consumes more disk space) then enlarging the picture causes it to become blurry, Check the camera and see what the Mega Pixel rating is. The bigger the number the better and more expensive the camera..
Feb 03, 2017 • Cameras
2answers
How do i enlarge photos/images?
In a photo editor like photo shop. Be aware even after enlarging a photo, it will not have more info. Small pictures have little info, and will be blurred when enlarged.
2answers
What is an enlarger?
As an engine is the heart of a car, so is an enlarger the heart of a darkroom. It is the instrument through which negatives are brought to life. Along with a good lens, it is the enlarger that the rest of the darkroom is built around. A darkroom can have the best plumbing, a great stereo and stainless steel trays, but without a good enlarger and lens, it can be hard to produce quality images.
Jan 17, 2013 • Photography
I like to print and enlarge my photos, often the enlargements are blurry. What settings could I being using on my DMCTZ2 camera to get a sharper quality picture?
First, here's a link to a free download of your manual. You should review it from time to time and consult it when you're stuck on a problem. The page numbers in my answer refer to this document.
The settings that impact overall image quality are:
1) ISO Sensitivity (Page 51). This is the sensitivity to light. A properly exposed picture taken at ISO 100 could be taken at ISO 400 in just 1/4 of the time. This means if the subject is blurry at ISO 100, you'll have a better chance of "freezing the action" if you shoot at ISO 400. Overall, the lower the value, the better the picture. Lower ISO values are ideal for bright, sunlit pictures. Higher values tend to be grainier, and are better suited for dark, overcast days and indoors under artificial light. I found shooting my DMC-ZS3 that ISO higher than 400 are too muddied for my liking - try the settings to see what is acceptable to you.
2) Picture Size (Page 52). Pictures that are set for 5M, 6M and 7M (5, 6 & 7 Megabytes respectively) contain a great deal more information than a picture taken of the exact same subject at 0.3M, 1M and 2M (300kb, 1 and 2 Megabytes respectively). A seven megabyte (7M) picture holds over 20 times more information than the 300kb (0.3M) picture of the same subject. This can be hard to detect on our small screens in the camera, but when viewed on a computer monitor, it starts to become noticeable - quickly. Viewing on a 17" computer screen is 8 times larger than the 2 inch screen of the camera - this is effectively "enlarging" the picture.
3) Picture Quality (Page 53). The TZ2 offers just two resolution settings. Standard and Fine. The Fine setting saves the most information possible about the picture and is much better choice than Standard. If high quality images that can be enlarged is what you're after - Fine should be where you leave this setting. Standard can be good choice for web graphics and simple 4x6 prints if you wish.
These settings do come at a cost however. In the example above, between the 0.3M and 7M pictures, you could take twenty (20) very low quality pictures on the 0.3M setting OR a just single high resolution picture in the same amount of space on the card. This means needing to carry more SD (or SDHC) cards or larger capacity SDHC card if you find you current card is filling up too fast with the high resolution / quality settings.
I hope this helps and good luck! Please rate my reply. Thank you.
I wish to enlarge a photograph from 4x6 to 5x7. Is this possible on this printer?
You can enlarge a photo to any bigger size that you require on any printer. However the clarity of the final product will depend on the resolution that that the original photo was taken at. If the camera resolution was anything abouve 5MP then you have nothing to worry.
2answers
Is there any way I can clear up a blurry picture on this camera once the pic is already taken?
On TV shows, they can take a blurry picture and enhance it to crystal clarity. In real life, however, those kinds of miracles aren't possible. In a photo editing program like Photoshop Elements, you can bring up the sharpness a little but you eventually reach a point where the picture no longer looks like a normal picture. The slogan is "garbage in...garbage out"...meaning you can only do so much to what you have to work with.
2answers
Can I enlarge pictures using this porinter?
Enlarging photos will definately lower the quality of the original photo try using some software like photoshop to enlarge it to some extent and then try to print.
2answers
How to get enlarge photo copy.i want enlarge form of my id card
go to reduction and enlargement setting and select enlarge it should indicate incriments going up
Fixing small objects
If you mean to enlarge a small low resolution image and make it a large image with good clarity and resolution, basically you can't really do this...
Well you can up to a point, say doubling the pixel size at maximum, but if you don't have the image size and qualitry to begin with, enlarging will rarely produce a clean image if you are enlarging it by a large factor.
Of course you can enlarge some images really well by say 25% by enlarging then using some sharpening filters like "Unsharp Mask" etc. You can get reasonable results this way, but if you are trying to say enlarge a 100 pixel wide image to 1000 pixels wide, it just won't work terribly well no matter how much sharpening or filtering you do!
Hope that helps!
Why do my Fun! Digital 320 pictures come out blurry?
Blurry images can be caused by any or all of the following: * Distance/Focus range -- the Fun! Digital 320 has a fixed focus range of 3 - 6 feet (1.8 meters) for brightly lit indoor photography, 3 ft. (1 meter) - infinity for outdoor photography. For best results, make sure that the camera is at least 3 feet away from the subject(s) when taking pictures. * Camera/Subject movement -- This is a common cause of blurriness, especially in low-light situations (see Lighting below). Hold the camera as steadily as possible while taking a photo, or use a tripod (a tripod mount is located on the bottom of the camera). Avoid subjects that are in motion. * Insufficient lighting -- the Fun! Digital 320 is designed for taking photos outdoors or in brightly lit environments. Inadequate lighting can exaggerate camera movement and contribute to blurred, "muddied," or uncrisp images. * Lens condition -- Check the lens periodically for smudges. If necessary, wipe the lens clean with a soft, lint-free cloth. Do not use cleaning solutions or chemically treated tissues. * Enlarging images using software -- otherwise normal digital images can appear to become blurry and/or blotchy when over-enlarged in software. To see an image's "true" appearance, use the software's Zoom In or Zoom Out feature to view it at 100%.
Top Sanyo Cameras Experts
NOEL
NOEL
Ngoro
Are you a Sanyo Camera Expert? Answer questions, earn points and help others
