Magic Chef 31000 Gas Kitchen Range Logo
Posted on Apr 05, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do you light the pilot for the oven? - Magic Chef 31000 Gas Kitchen Range
Anonymous
Level 3:
  • Magic Chef Master 43,501 Answers
  • Posted on Apr 05, 2010
Anonymous
Magic Chef Master
Level 3:
Answers
43501
Questions
0
Helped
10842661
Points
101584
Here is a tip that I wrote that will help you with that problem...
The ignitor for your burner has faied...
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
heatman101
Lighting pilot light on Magic Chef oven: CGS3760ADC
since it is piotless how did you light burner pilots? The oven is piotless and does not have a free standing pilot. here is a link to manual copy and paste page 18 deals with oven.
piotless
How do you light your pilot light on an kenmore oven
To light the pilot light on a Kenmore Maxitrol oven, please follow these steps:
  1. Locate the pilot light assembly. It's usually at the bottom of the oven, behind a small metal cover.
  2. Turn the oven control knob to the "off" position.
  3. Remove the metal cover by pulling it out or lifting it up, depending on the model.
  4. Locate the pilot light and the pilot light valve. The valve is usually a small red button located near the pilot light.
  5. Press and hold the pilot light valve in for a few seconds while you use a long match or lighter to light the pilot light.
  6. Once the pilot light is lit, continue holding the pilot light valve in for another 30 seconds.
  7. Release the pilot light valve and make sure the pilot light stays lit. If it doesn't, repeat the process.
  8. Replace the metal cover and turn the oven control knob to the desired temperature setting.
Note: If you're having trouble lighting the pilot light or keeping it lit, it may be best
Old wedgewood oven in home...very low pilot light in oven...how do I adjust it?
The oven pilot is usually located at the back of the oven; turn a screw on the pilot ignition unit to adjust the pilot flame height.
here is a link, pretty much all older ranges operate the same.
Gas Oven Pilot Lights Shutoff Valves and Ignition Systems HowStuffWorks
Amana oven pilot light
If you have a standing pilot and it is not on, you should be smelling gas in the house.
Try lighting it with a BBq lighter directly.
On some stoves, you will have to press a button and hold that button for some time ..over a minute..while you have the light to the middle of the pilot.
Do not proceed to light the pilot until there is no more smell of gas in the oven.
Oct 24, 2013 • Ovens
1helpful
When i turn on oven all i smell is gas i cleaned with a wire brush still nothing. also is the pilot light always have to be on and can you see it when oven is off
Most gas ovens that aren't electronic ignition usually have a pilot light.
Usually one in the oven area and one for each burner. (Sometimes shared between two burners.)
These pilot lights must lit at all times...otherwise it won't light up and you'll smell gas.
Usually the pilot light is in the very back of the oven and can be seen with the broiler drawer opened.
There is a small set screw located at the pilot light assembly in the oven and also at every burner.
This allows you to adjust pilot light up or down, thereby letting you set pilot light flame to a level that doesn't get blown out by a draft...or you can turn it off completely.
If you use that set screw to turn off the pilot light gas, you'd need to strike a match to light the oven or burners everytime you needed them.
Jul 17, 2011 • Ovens
2helpful
Oven pilot went out due to power outage. I don't know where the pilot oven light is. where is the pilot light to light the oven?Ge XL44
pilot over lights do not require power to stay light or should it go out in a power outage! do you have to normally light pilot with a match? if not you have a glow coil and its a electronic ignition range and power will affect it. once power is restored you should just be able to turn on over and everything would be ok.if it is a pilot light you need to remove the bottom door stick arm in to back and you'll see the pilot assembly at back if you look up! hopethis helps...
Feb 06, 2010 • GE Ovens
Magic Chef range the pilot on the oven will not light.
Is this a manual lighting pilot,do you light it?
If so you may have a bad gas valve.
If this is an auto light pilot it could be the electronic spark is bad.Im guessing the popping noise is the autospark trying to light.
Stove works just fine/oven does not warm up - pilot light is on, but turning on oven does nothing but make the pilot light glow a little bigger. Oven will not ignite.
Hi, The ignitor is getting weak and will not open the gas valve. Replace the ignitor and you will be back in business. This is a very common problem with the gas ovens.
Please let me know if I can assist you further.
Vic
May 29, 2009 • Ovens
1helpful
2answers
Gas oven dosnt work
the pilot light is there for 2 purposes. number 1 to light the burner and number 2 to heat up the thermocouple, thermocouple is a wire that the flame from pilot suppose to surround by fire. if the pilot is to low it will not reach the thermocouple. you can take the gas line that supplies gas to the pilot and clean it with a safety pin or a small needle. you can test the thermocouple by heating it up with a blow torch on low heat, get it red hot and then turned on the oven. if the oven works clean the pilot, if the oven do not work, replace the thermocouple if separate from safety valve. if thermocouple is part of it replace the safety valve.
Oven will not light
Most gas ranges currently available employ one of 3 basic gas ignition systems; pilot ignition, hot surface ignition system (which uses a 'glow bar' or 'glow coil' - aka an "ignitor") and a spark ignition system. The latter two being referred to as "electronic ignition" systems as they use electricity in one form or another to operate the oven heating system. Only the pilot ignition system has an actual "pilot" (which is a small but real "flame") which might need manual lighting.
If the surface burners of a range are a spark ignition type, the oven IS one of the possible kinds of electronic ignition systems and thus will not usually have a "pilot" which needs lighting. Be aware though that just because the surface burners might light via a spark doesn't necessarily mean the oven uses the spark type ignition system too. spark-anim1.90x11.gif
There is one older style of electronic ignition system which does also use an oven pilot but it is very rare and such a system hasn't been used in oven models since the early to mid 70's. It is the 'constant pilot' *electronic ignition* system
Top Magic Chef Kitchen Ranges Experts
Paul Carew
ZJ Limited
ZJ Limited
Are you a Magic Chef Kitchen Range Expert? Answer questions, earn points and help others
