I have a Compaq Presario 1200 that won't charge the battery. I have tried another battery with the same results. Any known problems with this or fixes.
Dear N9YK
you can follow this
If you have a loose connection where you plug in the power on your
laptop, or it works intermittently, you could have a bad dc jack.
Symptoms
Why does this happen?
or you can check your dc amper in your adaptor
oke
thx
cropp
1. The image quality is too low, but the display driver is installed....if I set my resolution to 1024 x 768, I cant see the start menu and the desktop becomes too big for the screen area.
2. The batery does not charge, but the charge light/led flashes as if it's charging. When I unplug it off the electricity mains, it doesn't even start on battery mode...it also doesn't show under windows (XP) that the battery is charging or not.
help me if you can.. my email address is [email protected].
