Camera keeps saying internal memory is full .Even afrer putting in a new memory card.
Your internal memory is separate from your memory card. Think of it as two folders, the internal memory cannot be removed, and the memory card is one you can take with you. You can put new memory cards in it all day, the internal memory will still have pictures in it. You may wish to consider copying all internal memory to the memory card. To do this, make sure your camera has a memory card in it. View pictures on your internal memory, then from the menu option select 'copy all images to external memory.' In doing this, all of your photos will be moved, you can then clean out your internal memory by deleting everything/formatting it. :)
Hello :
You need to format your cam's internal memory . Don't forget to format any external memory card before putting it in your cam .
good luck .
please don't forget to rate !
How do i copy all the images to external memory?
