D-Link 802.11g Wireless Router WBR-1310 (WBR1310) Logo
Anonymous Posted on Apr 03, 2010
Dlink wbr1310 router.
I recently purchased a used dlink wbr1310 router. It worked without any issues, unti I try to filter some web sites through the setup. I was able to enter the web sites and save it. After that the routher stopped responding. It shows the power indicator and the internet. When I plug my pc into it, the indicator does not come on. Same goes with the wireless. I tried to reset it several times, but when I press the botton nothing happens. Could some one help? Any help is greatly appreciated.
  • Anonymous Apr 11, 2010
    tried this and it did not work
  • Anonymous May 02, 2010
    triedit and did not work
Anonymous
Level 3:
  • Master 550 Answers
  • Posted on Apr 05, 2010
Anonymous
Master
Level 3:
Answers
550
Questions
Helped
420092
Points
1147
Press the reset button and hold it down for 30 seconds. release it. wait for a minute. unplug the power and plug it back in. wait for a minute. Now try to open the set up page of the router.
connect the computer to the router and check the IP address on that computer. using the default gateway number, try to open the set up page of the router.
Click here for step by step instructions
  • Anonymous May 01, 2010
    Click Here to try step by step solutions.
    Most of the users are using this web site for home network troubleshooting
1helpful
My WBR-1310 keeps losing connection every 10 mins or so. Is there a fix I can download to my router? (like an update or something)
I got your issue, since your facing the frequent disconnection in the internet connection,
ftp://ftp.dlink.com/Gateway/wbr1310/Firmware/wbr1310_firmware_104.bin.
Please download the firmware using this link and log into the router setup page of DLink with 192.168.0.1 and update the firmware
I'm sure this will help you to fix the issue.
Thanks & Regards,
Prema
Had a different router everything was working fine, until i replaced my router to a dlink dsl 2640u , wireless router. i can open all sites but sites beginning with https cant be opened. it says web page...
I suspect that you have port forwarding rule (virtual server) on port 443 (https) on your router. Try to remove rule or just reset router to factory settings. I have the same router and this problem did not happen. You can also install Router Commander program to boost up router performance.
I need to reinstall the driver for dlink but cant find the disk is there any free driver download site?
you should not need a CD to use the router - Routers do NOT need drivers. All the CD would do is set up the router - which you can do manually The product manual is available here http://www.dlink.com/products/?tab=3&pid=WBR-1310&rev=WBR-1310 goto the setup section where it explains how to setupthe router manually
2answers
Dlink wireless router
See if you can log into the router...in your browser type:
http://192.168.0.1
Username: admin
leave the password field blank.
there should be a setup button (I don't know if the setup program is in the router, but from the instruction manual, it should be).
Most of the settings should be the default settings, and there is some help listed. If your internet is working right now, it's probably not the router. You might try dlink.com to get the software that originally came on the CD.
I have a dlink dkt-110 and have no idea how to secure it without loosing it
Are you trying to secure the wireless network then you will need to access the router setup.
Is there any computer connected to the router?
If not then you will need to connect the computer to the router.
once you open to the router setup, you will see the option of secure the network.
Click here for more info
Cannot get a connection with the router installed. connection to internet works without the dlink .router works! Has been connected for 3 years
Better do reset the router and reconfigure it back , to reset it press and hold the reset button of the router for 10 seconds while power is ON and then reconfigure it back if you have the setup CD just run it....
7helpful
3answers
I forgot the username of dlink wbr-1310 wireless router
As an initial info try to do a hard reset on the unit, this process will restore the system into a original settings. you can find the reset switch on either on the left of right sight of your router.
or
you may visit this SITE to recover again your current password without erasing or removing the current settings made.
Reset Password.
Hope this idea helps you.
Thank you for using fixya.
Can not get wireless router to work
Follow this link
http://www.dlink.com/products/?pid=474&sec=0
D-LINK WILL HELP YOU...
Set up your new D-Link networkinghardware in minutes using our new Quick Setup Wizard. The wizard willguide you through an easy to follow process to install your newhardware and connect to your network. If you need additional help,visit D-Link’s award-winning Customer Support Web Site for answers tofrequently asked questions, product downloads, and easy access toD-Link’s friendly customer support team.
Do you clean your internet browsing history and temporary files on a regular basis?
Also: Try calling your DSL provider for tech assistance. The modem may need to be reset or upgraded.
2answers
Password
The username is admin
There is no password
Top D-Link Computers & Internet Experts
ExpressFiX
ExpressFiX
k24674
Grand Canyon Tech
Grand Canyon Tech
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
