Spinning seems OK, but sounds like a separate motor is not working/straining. Could it be water pump making loud humming? How to access/fix it?
More than likely the pump is clogged if you pull the the washer out away from the wall and then lean it back to get under it there is a hole to access the under side you can reach through to the pump then disconnect the large hose that goes from the tub to pump reach down inside of this hose remove the cup that has debris in it and clear it out remove the debris and reassemble the washer
it will put water in on certain rinse cycles, would the pump give off a hot smell?
