I have a printer with usb. Is there an usb-to-ethernet adapter I can use to connect my printer to rounter so that all PCs on network can use this printer?
Extender boost your wireless connection range. Adapter is use to connect to a wirelles connection (router) So let say you have a router far from your PC the extender boost your adapter range to get the router best signal
If the printer has wireless capability built in , no cables are necessary. Install the printer driver in the mac as a wireless connection. Connecting a printer to the router is pointless, unless you want to install the printer as a network printer, which would disable wireless.
There are many USB to ethernet adapters available, for example - Belkin USB to Ethernet Adapter with 2m Patch Cable from Amazon. Your laptop may only be USB version 1.0 so it would be best to make sur the adapter supports USB 1.0 and 2.0.
Without an ethernet port, you can't connect to a router. However, adapters are available which can adapt usb to ethernet. Check your local computer store.
All routers will only work with ethernet. You would need to get an ethernet card installed in your computer. You can probably buy one for about 20.00 at Walmart. If you don't want to do this you can purchase a usb/ethernet adapter and still use the usb port on your computer. You can purchase one of these for around 5.00's on ebay. Just go to ebay and search for usb/ethernet adapter. Please rate if this has helped. Thanks.
