My Frigidaire Dryer won't heat - I suspect it is the heating element. How do I change it and verify that it is the problem. The dryer tumbles. The model number is GLER642AS3 - Thanks
I have a frigidaire frontal dyer that is 3 yrs old. The dryer works properly, it tumbles, but it is only cold air ???? What's the problem ?
Dryer wont heat at all
After u cjk power ck the thermo fuse inside dryer top back side
Please check control thermistor first. Most likely and inexpensive part.
MK
Dryer won't heat, checked the 220 and it is good. have new coil for heater but don't know how to remove the heater. Have lifted the top and can see the heater but don't know how to remove it.
where do I find the thermal fuse on frigidaire dryer and hoow to replace it.
I have a Frigidaire Dryer. I am trying to find the fuses. Apparently, one of the fuses may be dead, and that would stop the heating of the clothes but not the tumbler.
It may also be the heater.
dryer won't heat and i've replaced the termistor what should i do next?
do you have 240volt into the dryer (at the plug)?? a dryer will tumble but wont heat if the power is missing a leg check that first
