Does the chain continue spinning? If no (and gasoline) bad clutch. If yes I suspect the bar and chain are binding (cutting in an arch). That is often caused by a worn bar or improperly sharpened chain. Post back (below) if the latter and I will help with that too. Post back with the model number (358.#####) and I will help with clutch replacement.
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
