I am trying to replace a chopper impeller in the bottom of a very old whirlpool dishwasher and can't get the chopper off (the grey plastic thingy). It was leaking out the bottom and they told us that it could be a diy job and that would take care of it
The leak is coming from the main seal? The chopper thingy on these old machines will not come out without a fight. These impellers have been there a long time and has had lots of hard water and crud to hold them on. Get a screwdriver or a reasonable facsimile and carefully bust it off. Be careful not to damage the shaft. If you pull the whole motor assembly out, replace the rubber gasket too.
Hi
The issue is with the water not draining as something might
be blocking the drain pump assembly thus the water is leaking. To solve this
issue you'll have to take the front lower access panel out and then clean the
drain pump assembly completely, also clean the impeller and chopper assembly
located at the bottom of the unit. After this is done the issue should be
resolved, if not then check the float switch mechanism and make sure that is
fine. Hope this helps...please post back for further assistance.
Daniel
Hi
Daniel
I have a whirlpool DU945PWPQO that is leaking from the bottom of the door. Is there a seal on the bottom of the door?
Whirlpool 24" DU900PCD is leaking from the door on the lower left hand side. The leak is intermittment, but has increased in frequency lately.
