Maytag Atlantis MAV9750A Top Load Washer Logo
Posted on Mar 15, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Plastic pulley melting
When my wife was washing clothes, strange noises started and you could smell burning. i thought wash load was off balance or there was some clothes that somehow got under the agitator. pulled agitator off. nothing was wrong. looked at belt - it was ok, but one of the pulleys (plastic) for the belt was melting. do you think the shaft is bad or any suggestions on the cause? thanks in advance jim
Anonymous
Level 2:
Sergeant:
  • Expert 288 Answers
  • Posted on Mar 15, 2008
Anonymous
Expert
Level 2:
Sergeant:
Answers
288
Questions
Helped
260004
Points
581
Whatever the pulley is attached to has seized. Either the water pump or tub drive, or something else has stopped spinning. The belt continued to run because the motor kept pulling it, and the friction from the belt melted the plastic pulley. Hopefully its the water pump, as its the most inexpensive. You should change the belt along with this fix, it has also got hot and probable will not last as long as it should.
I have a GE washing machine model # WCSR2090DAWW and today I went to put a load of clothes washing. It filled the tub up with water like normal and then went into soak mode. The problem starts when it...
Possible that some item of clothing is jamming up the drive to the tub. The burning smell are the motor windings reacting to the excess of electricity flowing thru them before they burn out.
MOTOR SMELLS OF BURNT MOTOR WINDINGS. iS IT NORMAL
No, the pump works while spinning. The burnt smell is probably the belt, especially if your wife saw smoke. Did she put a big load in it at the time?
The belt will slip until the tub catches up with the motor. If there is a heavy load, it can burn the belt up. I would replace it. Make sure the idler pulley on the motor moves freely also.
http://www.partselect.com/MultiModels.aspx?ModelNum=ALW480DA&searchTerm=&RefineSearch=0
Fisher & paykel GWL11 washer won't rinse
sounds like you have two problems, the burning smell is probably the pump,out of balance is usually due to worn aout suspension rods
Washer makes a squeel and burning smell
belt which operates pump/motor/transmission pulleys
A STRANGE SMELL WHEN DRYING..
sounds like brushes they can cause a burning smell......as for clothes smell after drying the fan in the heater could be dirty but generally that would mean the heater will not work
1helpful
Maytag washer stop spining and smell burned
two main things pump and motor pulley.the motor pulley on admiral designed maytags is plastic and melts and causes belt to burn.also pump pulley spot welds break causing pulley to drag.tip machine so rests on wall in back and you can inspect from there.hope that helps God bless ,tom
WASHER STARTS MAKING LOUD NOISES WHEN SPINNING SOUNDS LIKE IT IS OFF BALANCE BUT NOT. ALSO FAINT SMELL OF BURNT RUBBER.
The washing machine will do this if the load is unbalanced. Usually due to either an excessively heavy and/or large load. The burning rubber smell is just the drive belt dealing with the imbalance. Often the washing machine will self-balance itself, but it's a good idea to open the lid and re-distribute the load. Or remove some stuff if it seems too heavy.
2answers
Funky smell from working Whirlpool Ultimate Care II
run the washer then smell the motor or see if anything has jumped the tub and causing the clutch to pull harder
Washer smells burning, and is WAY off balance... HELP
if you are handy at fixing such things it is not too terribly hard to fix, but you will need to remove the drum. Hopefully, it is just a worn belt, you will also want to check the clutch, motor pulley and motor coupler. The motor coupler can also produce the burnt smell and the wet clothing. I would say it is definitely worth fixing. Get an estimate and go from there .
Top Maytag Washing Machines Experts
ZJ Limited
ZJ Limited
john h
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
