Heating & Cooling Logo
Anonymous Posted on Apr 01, 2010
Wiring diagram for electricmotor with capacitor
Wiring diagram for electric motor with capacitor.I need to conect a single phase fan motor with capacitor,diagram required.
Anonymous
Level 2:
  • Expert 308 Answers
  • Posted on Apr 01, 2010
Anonymous
Expert
Level 2:
Answers
308
Questions
Helped
152299
Points
748
I do not have a diagram for you, but depending on the motor, I can tell you a couple of things. 1. All capacitors are wired in series with the start winding. Most multi-speed motors, that require capacitors, have two brown leads, along with the motor winding leads. If this is the scenario, then just connect line power to neutral and the speed you wish to use, and connect the two brown leads, one to each side of the capacitor. Hope this helps.
Testimonial: "Thankyou for your assistance,very helpful."
1 Related Answer
bobicehouse
Robert Moller
  • 1524 Answers
  • Posted on May 12, 2010
SOURCE: wiring diagram for electricmotor with capacitor
On most motors the wires with the tabs are connected to the capacitor (usually brown). White wire is neutral and color wires are speeds.
2answers
Replace compacitor on Carrier 5 ton 3 phase AC
Your 3 phase unit should not have a capacitor. I'm guessing it's single phase. If it's a single capacitor than the compressor should not be going to it also. To test the motor, common to start plus common to run should equal the ohms you get between start and run. For instance, 1.2 ohms+ 2.2 ohms= 3.4 ohms. Follow the wiring diagram on the inside of the door, send model number!!
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
tip
How to Reverse the Rotation of Single Phase Capacitor-Start Electric Motors
Reversing the rotation of electric motors can be done easily with 3-phase motors. This can be easily achieved by swapping the connection of any two motor leads. But 3-phase motors are usually found and used for industrial purposes. The ones found and used in our homes, from water pumps to electric fans, are single phase capacitor-start type motors. Unlike 3-phase motors, reversing the rotation of single phase electric motors is no easy task. Swapping any two motor leads will not result in the reversal of the motor rotation. Analysis of the motor windings and connections are necessary before any modification can be done to achieve the desired result. Let's take a 3-speed single phase capacitor-start electric motor with electrical diagram shown below as an example. Make sure the motor is disconnected from the power supply before attempting to follow this tip. This tip is intended only for individuals with electrical knowledge, necessary tools, and understand the risks associated with handling electrical equipments and devices.
The first step in the process is determining the start winding which is connected to the line (AC white) and to one side of the start capacitor. To accurately determine the start winding, disconnect all motor leads from the start capacitor and the speed switch for multi-speed motors and then setting your ohmmeter to the lowest scale (R x 1), measure the resistances between the AC white line and each of the motor leads connecting to the start capacitor. The one with the least resistance is the starting winding lead.
Once the start winding lead going to the capacitor is determined, reconnect the capacitor then connect the black AC line to the found start winding lead (marked X). Connect the white AC line to L of speed switch, the motor lead formerly connected to AC white to 3, red to 2, and white to 1 as shown below. Leave the green/yellow ground wire connection as is.
Below are the wiring modifications for 2-speed and single speed single phase capacitor-start electric motors.
on Jan 11, 2011 • Dryers
2helpful
How do I wire a three phase electric motor to 110 plug
You can't run a 3-phase motor on 110V unless you use a 3-phase inverter. Depending on the size of your motor, these will probably run you around $150 for the least expensive type. Take a look at--- http://americanrotary.com/static-phase-converters.html
1helpful
Changed out blower motor on elect furnace.the old motor had three wires one fed the compaster.new motor is revirsable has purple wire,red,blue,black.hooked up purple 1st phase,red for high 2nd phase. is...
hmmm . you better check on that before firing it up ... normally the colored wires are for different speeds .. only one speed can be connected at a time .. usually the high speed winding is used for air conditioning and a lower speed winding is selected by a relay for heating .. ... the way the capacitor is hooked up determines which way the motor will turn .. your old motor with just 3 wires was probably a single speed motor .. normally the black wire will be connected permanantly to one phase .. the other phase then goes to the selected speed winding (color of wire) .. one goes to the starting capacitor . the others even if not connected will be hot electrically so need wire nuts to prevent shorts ..
Need a wiring diagram for 5kcp39fg general electric motor
if it has a brown/purple,and black wires and is a single phase motor, the purple and black are your 2 hot phase wires, and the brown goes to the motor capacitor and on other motor cap term that goes back to the purple phase wire
2answers
Wiring diagram for single phase two pole 2.5 HP induction motor.
all you have to do is (a) open the connection box of the motor look for the two wires of the starting or running coil, inverse only one coil wire.(a) If there is no centrifugal switch in the rotor, try this it might help open the motor both end,change the direction of the shaft ,which i mean pulley side goes to fan side and fan side goes to pulley side and tighten all bolts.
2answers
3helpful
Wiring a 220v single phase motor and capacitor
Black and white are usually power. an ohmmeter will confirm. Brown are for capacitors. There is almost always a diagram on the motor someplace. Eric
Top Heating & Cooling Experts
Paul Carew
john h
