Print quality issues on these models is usually if not always down to the cartridges used. I bet you are using compatible cartridges. If so just buy a set of genuine ones and I bet the quality will be perfect again.
If you are getting vertical faded streaks in the black print like this:
The problem is with the developer in the imaging unit. The problem can be fixed by either replacing the imaging unit for $100+ or you can fix it yourself by cleaning the imaging unit. You will need simple hand tools and if you are careful restore the print quality of your printer. I have a link to instructions that should help you http://www.fixya.com/support/r4120906-clean_developer_blades_samsung_clp_300 Hope this helps you.
this thing happened in my laptop also i got green screen fully then when i hit it behind the screen it was gone but comes many times then again i would hit later on the screen was completly lost then had to replace the screen yous is a starting period so go to a nearby computer service and fix the screen
Issue:
Banded or streaked prints Solution:
Change the Print Quality Settings (Windows)
The
Quality setting controls how finely ink droplets are placed on the
printed page. Depending on the type of paper being used a higher Print
Quality setting does not always insure a better print. Print speed will
decrease as the Print Quality setting is increased. Follow the
instructions below to change the print quality settings in the Canon
printer driver for the Windows operating system through a printing
application.
Click 'Properties' in the Print dialog box.
Note: Depending on the Application software, 'Properties' may be displayed as 'Preferences'.
Set the desired print quality in the 'Print Quality' section.
Select 'High', 'Standard', or 'Draft / Fast'.
To set more detailed print quality settings, follow this procedure:
Select 'Custom' and click 'Set'.
In the Set Print Quality dialog drag the slide bar from 'Fast' to 'Fine' to select the print quality.
Note: There are five options in 'Quality'. However, selectable options are limited depending on the media type.
Select 'Auto', 'Dither', or 'Diffusion' from the 'Halftoning' section.
Issue:
Print Head Alignment MP530
Perform Print Head Alignment
Instructions
to perform a Print Head Alignment directly from the machine. If
diagrams or ruled lines are misaligned, print head alignment is
required. The print head alignment can be performed automatically or manually. If the automatic print head alignment does not work, adjust the print head manually.
Automatic Print Head Alignment
Press <ON/OFF> to turn on the machine.
Load a few sheets of letter-sized plain paper in the auto sheet feeder.
Press
the Open button to open the Paper Output Tray. Then open up and set the
extension by pressing down the hollow on the front side.
Execute automatic print head alignment.
Press <COPY> button.
Press <Menu> repeatedly to select [MAINTENACE].
Press
the left or right cursor to select [AUTO HEAD ALIGN], then press the
<OK>. (A pattern is printed and the print head is automatically
aligned. It takes about five minutes to finish printing the pattern.)
Load two sheets of Letter-sized plain paper in the auto sheet feeder or cassette.
Ensure that the proper paper source is selected.
Execute manual print head alignment.
Press the left or right cursor to select [ALIGN PRINT HEAD], then press the <OK>. (The nozzle check pattern is printed.)
Check
the printed patterns and use the left or right arrow to input the
number of the pattern in column A that has the least noticeable streaks.
Press
<OK> to move the cursor to column B, and then use the left or
right arrow to input the number of the pattern that has the least
noticeable streaks.
Repeat the procedure until you finish inputting the pattern number for column P.
When you have finished inputting all pattern numbers, press <OK>.
Note: For columns A through N select the patterns with the least visible vertical streaks. For columns O and P select the patterns with the fewest visible horizontal streaks.
<1> Example of the pattern with the fewest visible vertical streak
<2> Example of the pattern with the most visible vertical streak
<1> Example of the pattern with the fewest visible horizontal streak
<2> Example of the pattern with the most visible horizontal streak
Issue:
Instructions
Press
Press
Check
Press
noticeable streaks.
I had exactly the same problem. Luckily we have 3 of these printers. Swapped the photoconductor and it solved the vertical streaking, even though the photoconductor was only half way through its life.
Instructions to
perform a Print Head Alignment directly from the machine. If diagrams
or ruled lines are misaligned, print head alignment is required. The
Press
Press
Check
Press
noticeable streaks.
