Open & close the top cover for 3 times while the printer is it will print a stand alone test page, also u can print the test page from the computer, if u r using xp then control pannel> printer & faxes> u will see the printer icon fro ur printer, right click on it , go to properties, click on print test page,
if u r using win 7 or vista in that case click start n in the start search type printers & hit entre the printer page will open, from there u will see your printer's icon so do exact same, u will get the test page.
cheers
Click on start go printers and faxes right click on printers go propeties
then click on print test page
Not possible in this printer
SOURCE: printer print only black while all cartridges are
Check your printer configuration and make sure you haven't mistakenly set it to monochrome (black and white).
SOURCE: i need a configuration page. the user is holding
Turn the printer on. Hold down the Shift Button and push SEL. This will put it in configuration mode. Release the Shift Button and press PARK to print a config page.
SOURCE: My HP Color LaserJet is
two possible problem:-
1. Check cable connected with printer and
2. driver of printer must be deleted or corrupted, re-install drivers..
