GE Profile JTP56 Electric Double Oven Logo
Posted on Apr 01, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My GE JTP45WOV2WW Double Oven is beeping with an F2 code and I don't know how to stop it
Anonymous
Level 2:
  • Expert 84 Answers
  • Posted on Apr 01, 2010
Anonymous
Expert
Level 2:
Answers
84
Questions
0
Helped
82518
Points
122
F2 means the controller thinks the oven is over temperature. (590degrees if door is unlocked, 990degrees if door is locked). This is a problem with either your temperature sensor or the control board.
If the temperature sensor is about 1080 ohms at room temperature, it is very likely the control board.
These can be rebuilt: www.fixyourboard.com
Beeps for no reason but no error code and oven works fine - a Whirlpool gold double oven
Oven keeps beeping:
As there is no reprogramming of most control boards try this, disconnect the power and wait 30 seconds and then reconnecting the power.
If it's an "F1" fault code this generally implies an electronic oven control (EOC) failure. Disconnect the power, wait 30 seconds or longer and then reapply power. If "F1" returns upon power-up, replace the electronic oven control.
The oven control can be accessed and replaced from the rear of the control panel.
NOTE:Disconnect the power cord from the power source before removing the panel from behind the console.
If its an F2 ERROR CODE, The F2 error indicates an open circuit in the oven temperature probe.
Your range has a resettable thermostat in series with the oven temperature probe. If this thermostat opens the clock will display F2 and the oven won't heat.
You can reset the thermostat by pushing in the reset button on top of the thermostat.
Some ovens have an alarm that will beep continuously every six seconds to alert you that the oven is still on. Usually, a kitchen timer that you have set will cause the beeping, but occasionally it can be an error with the oven's settings. If it is the kitchen timer, you can simply push the "Kitchen Timer On/Off" button to end the continuous beeping. If that does not stop the beeping, it is probably beeping due to an error. You can turn the continuous beeping off but you may still need to troubleshoot the issue that is causing the beeping noise.
Read more :
http://www.ehow.com/how_12086370_ge-oven-stop-beeping.html
Fisher double oven OD302. Periodically it will start beeping, shut off with no default code
Oven keeps beeping:
Read more :
How to Get GE Oven to Stop Beeping eHow
2answers
Tried to do self cleaning on oven, about 10 minutes in got "f2 locked door" and it won't clean. what is that all about?
Error code F2 on clean cycle is indicating that the maximum permissable cleaning temperature has been exceeded. (or it's got too hot!)
However it seems unlikely that that would happen in just 10 mins. more likely it is a problem with the oven temperature sensor which should be checked over as should the lock switches..
I'm getting a F2 Error and door locked with flashing and beeping after I ran the self-cleaning mode on my GE Model JTP85 built-in oven.
f 2 code states that your oven temp exceeds 590 w/unlocked door .. the oven tempt sensor will need to be replaced .. hope this helped mm
GE Double oven flashing F2
The f2 code means that the oven temp sencer needs to be replaced.
1helpful
Error code F2 keeps beeping! Will not reset. Any
thats the oven sensor , replace the sensor and your good to go
F2 message when self cleaning
I have the exact problem, had a service man look at it while still under warranty. He said it was fixed and left. Tried it again, same problem. Called him back 2 times after that, he quit responding to my calls. By tyhen warranty expired and GE refused to do anything.
Top GE Ovens Experts
ZJ Limited
ZJ Limited
Paul Bade
Are you a GE Oven Expert? Answer questions, earn points and help others
