Maytag pav2300 wont stop filling up. New timer installed. New hose from tub to water level switch. Can blow air thru hose to tub and i can blow air into the switch and it will work but with hose hooked up it will not work?
After the water fill, Switch off the mains, allow little water bleed through the hose that goes to the level switch. As the water flows try fixing into the level switch block.
Clean the water drips to dry and switch on the m/c. It should be alright since you say that the switch is OK when air is blowed!
