your drum bearings have gotten water in them due to a bad lip seal on the back side of the inner drum,if you can buy the bearings and lipseal you can tear it down and replace these rusty noisy bearings,and leaking seal
If your washer is not spinning ! You first need to drain it. Then underneath your washer you will find your drive system. It will consist of drive belt, drive pulley or pullies and motor. Belt could have come off , if so check the condition before reinstalling, also some times from overloading the belt will spin on the pulley which will make it hot and thanks to the manufacturer the pulley is likely plastic. Parts supply shops best source for belts and possibly pulley though sometimes they want to sale you the whole motor with pulley which you don't need. If so uae internet to find your pulley probably under 10.00 dollars. Hope this helps.
This is going to be the tub seal. Take the front off and check to see if the water is leaking right where the tub and the transmission meet and if so the seal is leaking. This also makes the washer noisy. This page should help http://appliance-repair-it.com/Maytag-tub-seal.html
There can be two possible reasons for it triping..
Firstly what im pretty sure it is, the motor... either your motor is faulty or your carbon brushes are worn... Im saying this because when the motor has to work at its hardest during the sping cylce it just cannot cope..
The other thing could be is that the drum has play within it and when spining quickly it is cathing the heating element probably already damaged it and therefore triping.
There your most likely faults
hope this helps.
The motor is located at the at the back on the bottom of the drum.
the heater is located at the back on the bottom of the drum .
Most likely is will not be the heater as it is more common on the older hotpoints.. But i thought id mention it
