March 2009
press the function key,select option #5, select option#2. This should take it out of child lock. If this doesn't work enclose your model number and I will try to look up the manual
Or, press "Cancel" three times to clear the (child) lock.
You set the lock by pressing "Start" three times.
Press the stop cancel button 3 times hope this helps
SOURCE: Panasonic Genius 800w locked
On many models, you press "Stop / Reset" three times.
A hard reset may help: Unplug it from the power line for a few minutes, plug it back in, set the clock, then try again.
If you don't have your owner's manual, you can probably download it (or one that's very close) here:
http://panasonic.co.uk/customer-Support/download-centre.asp
If that doesn't work, you can contact Panasonic UK at http://panasonic.co.uk/customer-Support/svc-dealer-locator.asp
We're happy to help and we appreciate your thoughtful rating of our answer.
press start 3 times to lock and 3 times to unlock...hope that helps
SOURCE: my panasonic genius sensor microwave says lock.
The
first thing I would suggest is a hard reset. Unplug the unit for a
minute or so. Then plug it back in, set the clock and try again.
leave it unplugged for about 5 minutes. Then let us know if the hard
reset does not fix it.
You can
download most Panasonic owner's manuals here. It will tell you how to turn off the Child Lock.
We're
happy to help you with free advice and we'd appreciate your
SOURCE: panasonic microwave genius 1300watt - can unlock
First of all, thank you very much for choosing FIXYA today for your technical support needs.
Here is a direct link to the ONLINE USER'S MANUAL for that model:
http://service.us.panasonic.com/OPERMANPDF/NNSD688S.PDF
To view the Owner's Manual with Operating Instructions just use your mouse to click on the link, which is the underlined and blue highlighted text just above.
This will open a new web browser page automatically for you and allow you to view the information at the website indicated and the contents of the Owner's Manual.
You may need ADOBE READER installed on your computer to read PDF documents, although many computers already have this type of utility pre-installed.
You can download this free at WWW.ADOBE.COM if necessary.
Click on the DOWNLOAD ADOBE READER button on right side of the ADOBE home page when you get there, then follow the onscreen instructions to install the software on your computer.
See page 10 of the manual for detailed instructions and illustrations on how to operate the CHILD LOCK feature.
Basically you just push the START button 3 times in a row TO ENABLE the child lock.
And press the STOP / RESET button 3 times in a row TO DISABLE that feature.
I truly hope that was helpful to you.
Some newer models require you to push those same buttons 4 times in a row instead in order to operate that feature so you can try that as well.
Good luck and take care.
Joe.
