Are both
the hot and cold water faucets turned on?
Turn on the water. Check the household faucets to see if the hot and
cold water faucets are turned on. Completely open both faucets for
proper fill.
NOTE: Both hot and cold water must be connected to
the washer
and turned on; the washer will not properly operate with only one incoming
source of water.
Turn off the water and remove inlet hoses from the inlet valves in the back of the washer. Inside the
inlet valves are screens. Remove any accumulated film or particles from
the screens. Reinstall hoses, turn on water, and check for leaks.
If the water pressure is too low, the washer
may not properly operate. To find out your exact pounds-per-square-inch (psi) value, contact your
local water utility company.
Use only HE High Efficiency detergent. Using non-HE detergent, or
more than the manufacturer's recommended amount of detergent, can cause
excessive suds. The excess suds can prevent the washer from detecting
the incoming water.
Concentrated detergents labeled 2x and higher will require a small
amount of detergent based on load size. Always follow the manufacturer's
recommendations.
Have the OBD codes read as there are a few things it could be , the codes will tell you which sensor/switch is at fault, will save you time and money searching blind , i'd think it is either the crank sensor or the coil pack but the codes will tell you definately
Dear
Please provide correct error code as the code you have provide is not complete it must be like below :
c:31:20
Shown above is the proper code way, please tell the proper code.
Get your codes read, I bought my code reader for less than $20 on ebay. Your looking for a OBD II code reader. Just a basic model tells you what the code is and can be translated by entering fault code into google.
Hi, F20 indicates a water inlet problem (no water or insufficient water supply) in your washer. To resolve this issue check your washer inlets, maybe the water valves are off or you don't have enough water pressure. Thank you!!
i think you are from india. so my solution for you is just get bsnl costumer care no. call them and tell ur name, last recharge amount, 20 or 16 digit code. they will tell you pin code or puk code. this is only solution for you.
Tenzin
