Using Alias 2 as Modem
In addition to the cable, you must subscribe to a specific service
through your cellular provider in order to use the Alias 2 as a modem.
This plan will be a "tethering" plan and will have a separate charge
each month to use it, similar to a cell phone's data plan. By signing up
for this feature, your phone will be able to dial into the data network
and utilize the Internet connection as a modem, allowing any connected
computer to surf the Internet. Once this feature has been activated on
your account the option will become available on the phone itself to
enable tethering.
At this point, you should be able to turn on
tethering, connect the phone to your computer via USB cable and select
the phone on your computer as an Internet connection source.
It
is important to note, however, that the Alias 2 uses a different and
slightly older system on the 3G cellular network. Because of this, using
the phone as an external modem will produce a slightly slower Internet
connection than a traditional modem or even a newer phone would.
However, as a backup solution for Internet connectivity or a travel
solution, the Alias 2 will work just fine as a modem for your computer
or laptop.
SOURCE: How do i fix a camera dsp error on my alias 2
9 times out of 10, if you pull the battery it will resolve the conflict.
SOURCE: I have a Samsung Alias 2 which has been fully
To make your Internet working you should first need the settings
for it.You cannot set it.Your network provider should give the default
gateway address for it.Then only you can use it.
If you already have
set the GPRS setting and now if it is not working because the network
service provider would have changed the gateway Ip address.You have to
again set the new one.
Please call your
network service provider and ask him to send the GPRS settings for your
mobile.He/she will ask for the mobile model and send you the
appropriate GPRS setting.You will get the settings as an SMS.go to iIbox
and save the setting...
Now you can work with it.Your phone has
no issues with GPRS.Only network service provider has to give the
correct settings.
Once you activate GPRS.MMS will also work
Please do rate the solution if the issue is
resolved or post a comment for further assistance.
thank you
for using fixya have a nice day:-)
Samsung PC Suite - Internet through mobile modem -Error 619 - Data Cable
Rectifying the error
1. Samsung USB modem driver (Download from Samsung ' Local Link)
2. Connect Your Samsung with a working Internet connection ( via )USB Cable
3. Samsung PC Studio or any other Samsung mobile drivers are not installed
Procedure
1. Connect your Samsung Star 3G to your PC and install the modem drivers that you have downloaded.
2. Goto Control Panel > Phone and Modem Options
3. Select the Modems tab. You will see Samsung mobile modem listed.
4. Select it and click on Properties.
5. Goto the Advanced tab and put the following in the box for Extra Initialization Commands:
+cgdcont=1,"IP","your_apn_name"
( or tye AT+CGDCONT=1, "IP', "apnname")
eg:- +cgdcont=1, "IP", "bsnlnet"
6. Hit OK and exit.
The next step is to create a dialler for your Samsung Star 3G mobile modem.
Error 619 solved
1. To create a dialler, Goto Control Panel>Network Connections
2. Hit Create a New Connection and proceed as follows (each sub-point is for each screen of the wizard):
2.1 Network Connection Type: Connect to the Internet
2.2 How do you want to connect to the Internet: Set up my connection manually
2.3 Select Connect using a dial-up modem
2.4 Select Modem-Samsung Mobile Modem
2.5 Type an ISP name according to your preference (could be anything)
2.6 Type*99# as the phone number ( or type *99*1*1# or *99***1# )
2.7 Leave Username, Password and Confirm Password fields blank
2.8 Hit Finish
That would complete the wizard and make a dial-up connection for you. Dial it and you will be connected to the Internet via your Samsung Star 3G phone modem without using Samsung PC Studio
