I have a Kenmore he3t and water will leak into the tub when unit it not in use.
This problem is commonly attributed to either a leaking water inlet valve, or a pressure switch malfunction. The following link explains how to diagnose the problem and repair as necessary:
http://www.fixya.com/support/r3753262-front_load_washer_fills_when_not_in_use
Replacement parts (if required) can be purchased at any of the following websites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
All these sites are reputable and offer great service with competitive pricing, so shop and compare. The first three sites I listed also include helpful exploded view parts diagrams to assist you in locating and properly identifying the parts you need.
If you have any questions, please post back and let me know. I hope this helps you.
You got it. Water Level Switch and Pressure Switch are one in the same. Before you purchase a new switch make sure the small air hose on the switch is still attached to the switch, and at the opposite end on the wash tub. If this hose is dislodged, clogged, or has any leaks (such as holes, rips or cuts) it will give the same symptoms. Good luck to you.
I unpluged the washer and left the water on and it did not leak. According to the troubleshooting this means it is the "Pressure Switch". Kenmore does not offer a part called "Pressure Switch". Is "Water Level Switch" the same thing? (p/n: 8181695) Thanks!
