Canon ZR90 Mini DV Digital Camcorder Logo
Posted on Mar 15, 2008
Can't get my Cannon zr 90 to work, there's a flashing red light in viewer
Hello, lost my manual for this camcorder and can't get the thing to work, would record in video mode, is ther a way to down load the user's manual?
Thanks for nay help most appreciated
  Patrick
A
Anonymous
Yes, I found the manual downloads on Canon's webpage. I wish I could figure out how to transfer my tape videos to a computer. I bought the $50,00 DV-1394 cord and nothing happens--computer doesn't recognize the camera.
I need an instruction manual for NTSC ZR 90 mini DV Do you know where I can get it???
http://www.usa.canon.com/cusa/support/consumer/camcorders/minidv_camcorders/zr90
Hello I have got camera Sanyo Xacti vpc - ca9gx. Recently i lost mic but camera still was recording but after while stop working. On the top is red light flashing but it is not starting. I have open the...
Think you have it about thin sheets like fcc flatcontactcable that can about problems with sun heat build up inside there are special hotmelt repairs something like this kind of fcc without tools very difficult . hope you can something do with it knowing that Sanyo was become a part of PANASONIC in 2008
How to repair Flex cable Flexible PCB type flat copper ribbon cable Sanyo VPC CA9 Xacti Camcorder 720p Quick Manual
HELLO, MY CANNON ZR 100 IS STUCK IN PAUSE MODE
This is most likely due to a failed Pause / Play switch and can be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be repaired by a qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com.
Tape is stuck in cannon zr 100 camera and will not eject
There should be a manual eject button. You know like on CD-ROM's there was a small whole for a paperclip to fit into, there should be one on that camera. This will eject manual, and becareful the tape might be caught on the head.
6helpful
What is red blinking light on Cannon ZR45MC screen? Will it show up on DV tape?
Hello, I just bought a canon zr45 today off a friend without the owners manual. I had the same problem. It is flashing because it needs a new 3 volt lithium battery. This is a back up battery. It is located underneath the regular battery pack. Take the regular battery pack off and you will see where it goes. I changed mine and it doesn't do it anymore. It shouldn't show up on your recordings. It didn't on mine. Also, you can download an owners manual for free off the internet. Just key in canon zr45 owners manual and you will see links that will take you there. I hope this helps.
2helpful
How do i set up my canon zr 90 as a web cam on my mac
mobiola
http://www.warelex.com/products/webcam/
that website let you to make mobile camera as webcame you can search and find zr 90 to make it as wecame
mamdouh//newuser
[email protected]
4helpful
Flashing red icon on canon zr 900 not addressed in manual?
Check to see if the small lithium battery (size of a dime) is installed behind the battery pack. This stores the date/time when rechargeable battery is low or off.
My camcorder-camera doesn't charge....
Ihave a canon zr 40 mini digital vidio camera it want take charge the battery is new.Does it have to be off to charge it? IT is suppose to flash when charging and it want can you helpme with this problem?
Top Canon Video Cameras Experts
NOEL
NOEL
john h
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
