HP J4680 Office Jet All-In-One Printer Logo
Posted on Mar 31, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Duplex printing not happening - HP J4680 Office Jet All-In-One Printer
Anonymous
Level 3:
  • Master 590 Answers
  • Posted on Mar 31, 2010
Anonymous
Master
Level 3:
Answers
590
Questions
Helped
149145
Points
1722
In your printer model duplex printing is not supported. But it can be achieved using the manual duplex printing option. In the printer properties select the type of duplex printing you want to take and click on print. Once the printing got over on one side of the papers, then you will be prompted to turn the whole printed paper bundle and keep in the tray again and continue the printing. Now by this way duplex printing is done in your printer model.
I hope this is useful to you.
Please rate the solution provided.
Thanks
When I make a Duplex copying,it is copied at the wrong position only on the front side.
check that you are using duplex and left binding. also does this happen with other files??? does it happen with different program pdf , word etc.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
User tries to print double-sided but only the first page goes into the duplex unit and the printer says Processing duplex job but nothing else happens [except the odd clunk]. Switching off printer clears...
The error you have seems to be a memory error. Try some of the suggestions listed <a href="http://forums13.itrc.hp.com/service/forums/bizsupport/questionanswer.do?threadId=1083081&admit=109447627+1260869270520+28353475">here</a>
3helpful
2answers
Do pixma Mp610 support duplex printing
The MP610 does support duplex printing.
Duplex Printing
The duplex printing function allows you to print data on both sides of a sheet of paper.
The procedure for performing duplex printing is as follows:
Performing automatic duplex printing
You can perform the duplex printing without having to turn over the paper.
1. Open the printer driver setup window, check the Duplex Printing check box, and confirm that Automatic is checked.
2. Select Normal-size Printing (or Fit-to-Page Printing, Scaled Printing or Page Layout Printing) from the Page Layout list.
3. When printing a document that has small margins, click Print Area Setup... and set the print area.
When you perform duplex printing, the print area of the document becomes slightly narrower than usual and the document may not fit on one page.
sub.gifTo print without reducing the page:
Select Use normal-size printing.
sub.gifTo reduce the page slightly during printing:
Select Use reduced printing.
4. Specify Staple Side.
The printer analyzes the Orientation and Page Layout settings, and automatically selects the best staple position. Check the Staple Side setting. If you want to change the setting, select another value from the list.
5. If necessary, click Specify Margin... and set the Margin width.
6. Click OK.
Duplex printing will be started.
Performing duplex printing manually
You can perform the duplex printing manually.
1. Check the Duplex Printing check box and uncheck the Automatic check box on the Page Setup tab.
3. Specify Staple Side.
4. If necessary, click Specify Margin... and set the Margin width.
5. Click OK.
sub.gifIf a media type other than Photo Paper Plus Double Sided is selected for Media Type on the Main tab:
When you execute print, the document will be printed on one side of a sheet of paper. When printing is complete, reload paper according to the displayed message and then click OK. The document will be printed on the opposite side.
sub.gifIf Photo Paper Plus Double Sided is selected for Media Type on the Main tab:
When you execute print, the document will be printed front and back alternately for one sheet at a time. Load the paper according to the displayed messages.
caution.gif Note sub.gifDuplex Printing is unavailable when:
- A media type other than Plain Paper, Photo Paper Plus Double Sided or Hagaki is selected from the Media Type list.
- Poster Printing is selected from the Page Layout list.
sub.gifWhen Booklet Printing is selected from the Page Layout list, Duplex Printing and Staple Side appear grayed out and are unavailable.
sub.gifAfter printing the front page, there is an ink drying wait time before starting to print the back page (Operation stops temporarily). Do not touch the paper during the time. You can change the Ink Drying Wait Time at Custom Settings on the Maintenance tab of the printer driver.
sub.gifWhen you perform the automatic duplex printing for Hagaki, print an address first and then print your message.
refer.gif Tip sub.gifIf you select Photo Paper Plus Double Sided for Media Type on the Main tab, the Duplex Printing check box on the Page Setup tab is not checked automatically. To perform duplex printing, check the Duplex Printing check box.
sub.gifIf the Media Type dialog box appears when performing borderless printing during duplex printing, select Plain Paper or Photo Paper Plus Double Sided.
sub.gifWhen performing the automatic duplex printing, do not use any plain paper smaller than A5. Also, do not select any type of paper other than Plain Paper, Photo Paper Plus Double Sided or Hagaki at Media Type.
sub.gifPhoto Paper Plus Double Sided is highly recommended for printing photographs on both sides of a page.
sub.gifIf the back side of the paper becomes smudged during duplex printing, perform Bottom Plate Cleaning in the Maintenance tab.
CLP 510 prints only two sheets duplex and stops
There must be some problem in your settings. Check it out properly
4answers
Not printing double sided
check the driver
does not print from bypass tray (manual feed)
does not print on thick paper (check paper type)
3helpful
Hp laserjet 4250
This happens when the printer is printing duplex job. i.e. trying to print the other side of the page.
However check the functionality of the printer by performing Paper path test.
This would help us to know whether the printer as a stand alone ... is fine or not.
From the control panel of the printer, scroll to Diagnostic > paper path test.
Select the following in sequence.
Source: All trays
Copies: 10
Duplex: ON
Print Test Page
Check if you get the same error.
If yes, upgrade teh firmware of the printer.
Let me know the end result. We still have more depending on the above test.
- Nikhil
C7280 printer will not duplex print
This only happens using wireless.
plug in the usb port to the pc
let it install automatically
turn off pc, unplug printer
turn on pc, adj printer prefs for wireless
fixed
Trouble with duplex printing
I think your problem is that the 5550 supports manual duplex printing. Print every other page then feed them through again. Never tried it though. Dave Reed
Duplex Printing
do you have duplex installed ? if you trying to copy duplex originals, you need duplex feeder.. in main displey the left tab is dupleks printing, if you have there options 1 -1; 2-1; 1-2; 2-2 then you have a duplex installed and you can copy/print duplex. also in driver menu there is a option duplex, wath you have to choose if you printing.
k24674
Grand Canyon Tech
Grand Canyon Tech
