Saniflo & Saniplus& Macerator Pump  Logo
Posted on Mar 31, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Not pumping fitted saniflo according to instruction but just cannot get to pump .Has the pump to be primed?
Anonymous
Level 2:
  • Expert 349 Answers
  • Posted on Jun 11, 2010
Anonymous
Expert
Level 2:
Answers
349
Questions
0
Helped
218331
Points
696
Http://plumbingmall.org/PDFs/Saniflo/SaniPlus_installation_US.pdf
This link has information on your unit page 14 has troubleshooting guide along with installation instructions that maybe helpful to you.
  • kazem aleid
    kazem aleid Feb 09, 2018
    safari can not open the link
1helpful
I got a saniflo plus but motor runs but pump is not pumping?
The internal motor capacitor has failed - most common problem with these units
I have posted repair instructions here:
Saniplus repair instructions
It is a PDF
My Sanilflo system is fed by a toilet and a sink. When the sink fills it to operating the grinder runs for about 5 seconds and switches off. When the toilet is flushed (no solids) the grinder runs for...
The amount of time that the pump operates is determined by the amount of water that is drained into the unit. If the amount of water from the sink is less them the amount flushed then the pump will run accordingly.
Need to fit a toilet to an upstairs room with only a 2 inch pipe for evacuations of water and waste ,a hand basin also
The perfect solution will be to use a Sanitop, Sanicompact 48 or the Sanistar model. Visit the Saniflo website at www.saniflo.com for more detailed information.
2helpful
My Saniflo toilet has just started to pump/grind every half an hour of its own accord, I have had to switch it off as I am worried it will cause more damage.
sounds like the backflo preventer is bad letting water back down from system the backflo is the fitting is in the elbow fitting on top get a bucket when you loosen connection water from pipe will flow out then take elbow out of tank the backflow is the valve in bottom of the elbow it has a twist lock take out and clean if its cracked or any reason will not stay closed replace it
11helpful
3answers
Saniflo Saniplus won't stop pumping
is it pumping against gravity? if so there is a non-return flap in the outlet spigot could be stuck or worn.
Saniflo sanibest continually running , noisy ...
The float switch will be the problem.
We do not replace the switch, just change the unit as labour to strip and replace switch makes it un economical.
1helpful
2answers
My saniflo pump has stop working, what can be wrong
Have you got power to the pump? .. if it is on a fused spur, check that there is power (i.e. check the mains switch board)
My Stay Rite Pump 1 hp, 230 volt model DS3HE - 01 runs, but does not operate my irrigation system with any pressure. I resume the pump has lost its prime, but have no clue as to what I might do to fix it?
pumps lose prime for a few reasons...bad foot/check valve, crack in the suction line are probably the two most common.. see if there is a threaded fitting( most pros put one on the pipe some where) on the top feed of the pump. open it up and add water til the pump fills up. if the pump is outside turn the pump on before resealing the fitting, otherwise resael the fitting and open a spicket outside. depending on your water table it could take some time to prime but in normal circumstances up to 20 minsif it does not prime you may want to consider hiring a pro!!
1helpful
How to install toilet macerator?
on your out put pipe make sure you put as few turns and bends in it as you can, this will help the pump out when it's grinding and pushing it up. also you will want to use schedule 80 pvc pipe if you can get it and make sure you prime and glue every fitting well because you do not want that to leak when it's started up. it's always good to put a check valve on it as well some where close to where it enters the tank and a shut off valve, the glued pvc valves are handy because you dont have to worry about them leaking
Top Saniflo Home Experts
ZJ Limited
ZJ Limited
Paul Carew
Are you a Saniflo Home Expert? Answer questions, earn points and help others
