Ntldr cd boot fault - Computers & Internet
  • Hilton Bristol May 11, 2010
    I AM NOT CLEAR ON WHAT YOU MEAN
My computer show window is corrupt????? I know i need that CD thing, I can not find it, where can I get one????
Posted on Sep 08, 2012
    New Friend:
  • 84 Answers
Computer is booting from a non-bootable source
Many times this error is caused when the computer is attempting to boot from a non-bootable floppy disk or CD-ROM. First verify that no floppy diskette is in the computer, unless you are attempting to boot from a diskette.
If you are attempting to boot from a floppy diskette and are receiving this error message it is likely that the diskette does not have all the necessary files and/or is corrupt.
If you are attempting to install Windows XP or Windows 2000 and are receiving this error message as the computer is booting verify that your computer BIOS has the proper boot settings. For example, if you are attempting to run the install from the CD-ROM make sure the CD-ROM is the first boot device, and not the hard disk drive.
Second, when the computer is booting you should receive the below prompt.
Press any key to boot from the CD
Important: When you see this message press any key such as the Enter key immediately, otherwise it will try booting from the hard drive and likely get the NTLDR error again
Posted on Mar 31, 2010
2 Suggested Answers
6ya staff
SOURCE:
emma00
Havaida batool
  • 32 Answers
SOURCE: Error message on boot: NTLDR is missing. Set to
Follow this link:
http://www.tinyempire.com/notes/ntldrismissing.htm
than tell its solved or not.
Posted on Feb 18, 2010
My windows XP has an error message when started. It says "MISSING NTLDR, PRESS CTRL, ALT, DEL TO RESTART" I tried restart with boot disk but nothing. Please help!?
How to Fix NTLDR Errors
  1. Restart the PC. The NTLDR error could be a fluke.
  2. Check your floppy and optical (CD/DVD/BD) drives for media and disconnect any external drives. Often times, the "NTLDR is Missing" error will appear if your PC is trying to boot to a non-bootable floppy disk, CD/DVD/BD, or external hard drive or flash drive.
    Note: If you find that this is the cause of your problem and it's happening a lot, you might want to consider changing the boot order in BIOS so the hard drive with Windows installed is listed first.
  3. Check the hard drive and other drive settings in BIOS and ensure they are correct. The BIOS configuration tells the computer how to use a drive so incorrect settings can cause problems, including NTLDR errors.
    Note: There is usually an Auto setting for hard drive and optical drive configurations in BIOS which is usually a safe bet if you're not sure what to do.
  4. Restore the NTLDR and ntdetect.com files from the Windows XP CD. Restoring these two important system files from the original Windows XP CD may do the trick.
  5. Repair or replace the boot.ini file. This will prevent the NTLDR error if the cause of the problem is a boot.ini file that is not configured properly for your Windows XP installation.
  6. Write a new partition boot sector to the Windows XP system partition. If the partition boot sector has become corrupt or isn't properly configured, you may receive the "NTLDR is Missing" error.
  7. Repair the Windows XP master boot record. NTLDR error messages may also appear if the master boot record is corrupt.
  8. Reseat all internal data and power cables. NTLDR error messages could be caused by loose or malfunctioning IDE cables.
    Try replacing the IDE cable cable if you suspect it might be faulty.
  9. Update your motherboard's BIOS. Occasionally, an outdated BIOS version can cause the "NTLDR is Missing" error.
  10. Perform a repair installation of Windows XP. This type of installation should replace any missing or corrupt files. Continue troubleshooting if this does not resolve the issue.
  11. Perform a clean installation of Windows XP. This type of installation will completely remove Windows XP from your PC and install it again from scratch. While this will almost certainly resolve any NTLDR errors, it is a time consuming process due to the fact that all of your data must be backed up and then later restored.
    If you can't gain access to your files to back them up, understand that you will
Jan 22, 2014 | Belkin Basic Wireless Router
NTLDR missing on XP desktop
NTLDR is the boot loader for windows XP. This is the part the kick starts the entire process of XP loading. It is located at C:\NTLDR One of the easier ways to fix this is Either boot in to the recover console from a Windows XP disc, or download Hiren Boot CD, burn it to a disc. Insert the CD into your Dell and reboot the computer. Note you may need to enter BIOS and enable boot to CD/DVD. Once at the Hiren menu, select Boot Mini XP. Once the Mini XP loads you can copy NTLDR loader from the mini xp to your C:\ drive. Then remove the disc and reboot the computer.
Jun 11, 2012 | Computers & Internet
17HEWLET-PACKARD NTLDR IS MISSING
See the following web site for help on fixing this problem or alternatively, download a copy of Hiren's Boot CD and burn this CD image file (ISO) to a blank CD, then boot your computer from the CD and take the option on the boot menu to Fix NTLDR is Missing.
Jan 12, 2012 | Compaq Computers & Internet
NTLDR is missing
NTLDR is missing" means that the Windows boot loader (NT Loader, NTLDR) cannot be found. This often occurs when the computer tries to boot from a drive other than the one Windows is installed on, due to a change in the drive configuration or because you left a bootable disk in a removable drive. But it may also be because the NTLDR file has been corrupted or deleted
  • Check that there are no CDs or DVDs in the CD/DVD drives.
  • Check that no removable drives are plugged in to the USB ports.
  • Check the boot order in the BIOS Setup to ensure that the computer boots from the drive containing Windows before any other bootable devices
  • However, if your computer is using Windows XP and you have a Windows XP installation CD you may be able to boot from this and use the Recovery Console to fix NTLDR manually .
    Jan 02, 2011 | ASUS Eee PC 900 Notebook
    Nltdr missing
    How To: Fix "NTLDR is missing"
    Applies to: Microsoft Windows NT, Windows 2000, Windows XP
    Symptoms
    When you start your computer, you receive the error message "NTLDR is missing. Press any key to restart."
    Cause
    The error message "NTLDR is missing" means that the Windows boot loader (NT Loader, NTLDR) cannot be found. This oftenoccurs when the computer tries to boot from a drive other than the one Windows is installed on, due to a change in the driveconfiguration or because you left a bootable disk in a removable drive. But it may also be because the NTLDR file has beencorrupted or deleted.
    SolutionCheck the boot drives
    First, check the boot drives to make sure that the computer is not trying to boot from a different drive to the one thatcontains Windows.
    • Check the boot order in the BIOS Setup to ensure that the computer boots from the drive containing Windows before any other bootable devices.
    If this does not resolve the problem, you will have to repair the NT boot loader.
    Fix NTLDR
    The easiest way to fix the "NTLDR is missing" error is to use Spotmau PowerSuite.However, if your computer is using Windows XP and you have a Windows XP installation CD you may be able to boot from this anduse the Recovery Console to fix NTLDR manually instead.
    Use Spotmau PowerSuiteInsert the Spotmau PowerSuite CD and start the computer. The main menu will appear.spotmau-2.gif
    • Click 2. Windows Recovery.
    • When the Windows Recovery tool starts, click Windows NT/2000/XP/2003.
    • On the Windows NT/2000/XP/2003 Recovery dialog, click Recover NTLDR and NTDETECT.
    • On the Recover NTLDR and NTDETECT dialog, select your operating system (e.g. Windows XP) and then click Recover.
    The tool will repair the file and report "NTLDR and NTDETECT have been recovered successfully."
    • Remove the Spotmau PowerTools CD from the drive and click Restart to reboot the computer.
    Here link of the program Spotmau PowerSuite 2010 + Serial Download
    Here link of the program Spotmau PowerSuite 2010 v5.1.1.4846 Download
    Please Rate Me
    Nov 17, 2010 | HP Pavilion dv6000z Notebook
    NTLDR is missing
    this is a very common Issue:NTLDR is Missing.
    Related errors:
    Below are the full error messages that may be seen when the computer is booting.
    NTLDR is Missing
    Boot: Couldn't find NTLDR
    Please insert another disk
    NTLDR is missing
    Press Ctrl Alt Del to Restart
    Causes:
    1. Computer is booting from a non-bootable source.
    2. Computer hard disk drive is not properly setup in BIOS.
    3. Corrupt NTLDR and/or NTDETECT.COM file.
    4. Misconfiguration with the boot.ini file.
    5. Attempting to upgrade from a Windows 95, 98, or ME computer that is using FAT32.
    6. New hard disk drive being added.
    7. Corrupt boot sector / master boot record.
    8. Seriously corrupted version of Windows 2000 or Windows XP.
    9. Loose or Faulty IDE/EIDE hard disk drive cable.
    10. Failing to enable USB keyboard support in the BIOS.
    Windows XP users
    1. Insert the Windows XP bootable CD into the computer.
    2. When prompted to press any key to boot from the CD, press any key.
    3. Once in the Windows XP setup menu press the "R" key to repair Windows.
    4. Log into your Windows installation by pressing the "1" key and pressing enter.
    5. You will then be prompted for your administrator password, enter that password.
    6. Copy the below two files to the root directory of the primary hard disk. In the below example we are copying these files from the CD-ROM drive letter, which in this case is "e." This letter may be different on your computer.
      copy e:\i386\ntldr c:\
      copy e:\i386\ntdetect.com c:\
    7. Once both of these files have been successfully copied, remove the CD from the computer and reboot.
    hope that it will be help full
    thanks
    Oct 27, 2010 | Dell Computers & Internet
    NTLDR is missing problem
    NTLDR is NT Loader program and corrupted or missing NTLDR will not allow you to boot up.
    Keep your Operating system Bootable CD ready and boot your computer with CDROM. Follow below instructions to repair NTLDR
    1. In Windows XP Setup menu press "R" to repair
    2. It will show you windows to login (1. Windows )
    press 1 and provide administrator user id and password.
    3. one in command prompt you have to copy paste NTLDR file from cdrom to c:\ type the following command
    Your cd drive letter you need to figure out. Here I am taking it as d:\
    or make sure you below command runs by changing drive letter if not able to determine CD drive letter
    copy d:\i386\ntldr c:\
    Restart the computer and it should work.
    Else, again boot from CD ignore Repair option to go in recovery console, and hit enter. It will show you the agreement . Press F8 to accept . Next screen will show you option to repair to continue to fresh installation.
    Here press "R" to repair. Not sit back it will take time to repair complete system.
    Hope this helps
    Jun 10, 2010 | Compaq Armada M700 Notebook
    Ntldr is missing
    Hi kenudorn. ntldr is missing means that your Windows is corrupt. You need a Windows CD and boot from it. If you have the Windows CD is inserted and you still get the ntldr is missing is probably because you dont have the CD to boot first on the BIOS. If you DO have it to boot first, then it means the CD Rom is not reading the CD and you might have to get it replaced. I hope this helps. Please do not forget to rate and provide positive feedback for our fast-free support today. Thank you :D
    May 01, 2010 | Dell Computers & Internet
    Dell computer running windows xp will not boot. NTLDR compressed
    best thing to do if you can get one is a propper install disk and then follow these instructions..
    1. Start the Recovery Console. If you do not have the Recovery Console installed, start it from the Windows Xp compact disc (CD). To do this, follow these steps:
    a. Insert the Windows XP CD and restart the computer. If prompted, select any options required to boot from the CD.
    b. When the text-based part of Setup begins, follow the prompts; choose the repair or recover option by pressing R.
    c. If you have a dual-boot or multiple-boot system, choose the installation that you need to access from the recovery console.
    d. When prompted, type the Administrator password.
    2. At the command prompt, type "cd \" (without the quotation marks), and then press ENTER.
    3. Type "ren ntldr ntldr.old" (without the quotation marks), and then press ENTER.
    4. Type "map" (without the quotation marks), and then press ENTER.
    5. Note the drive letter assigned to the CD-ROM drive that contains the Windows XP CD. It is displayed in a format similar to the following: D: \Device\CdRom0
    6. Type "expand <drive>\i386\ntldr._" (without the quotation marks) (where <drive> is the drive letter of the CD-ROM drive that contains the Windows XP CD), and then press ENTER. For example:
    Expand d:\i386\ntldr._ <ENTER>
    Note the underscore character after the "."
    The following message appears: ntldr, 1 file(s) expanded.
    7. Type "exit" (without the quotation marks). The computer restarts.
    8. Remove the Windows XP CD and start the computer normally.
    Jul 07, 2009 | Compaq Presario 4090US (470016-303) PC...
    Ntldr
    First check your bios & make sure it see's your hard drive & it's setup correctly. If it is there could can be other reasons for the missing NTLDR.
    Suggest you take you Windows CD and boot to it. If your CD does not boot. Re-start the PC & start pressing the F8 key every two seconds. This will bring up a boot menue. Choose your cdrom drive.
    Once in the Windows XP setup menu press the "R" key to repair Windows. Log into your Windows installation by pressing the "1" key and pressing enter. You will then be prompted for your administrator password, enter that password. Copy these two files to you Hd. copy e:\i386\ntldr c:\
    Replace the drive letter listed above for your cdrom's drive letter.
    Once copy has been complete re-boot your Pc.
    If you still get missing NTLDR. Do a complete reinstall of windows. Your personal data should stay intact.
    Please post back if this has not fixed missing NTLDR, there are more fix's that can be applied. I only listed the most common.
    Feb 12, 2008 | AOpen Motherboards: AX4SG-UN (AAX4SGUN)
    Computers & Internet Logo
    149 people viewed this question
    Ekse
    Marvin
    Marvin
