Hello. Remove the cartridges from the printer. Close the cover. Unplug the printer from the power source. Plug the printer back to the power source. When it's still making the clicking sound, check inside of the printer for anything out of the ordinary inside it (loose strips, loose belt or springs, etc.). When you have any of these, call Lexmark. They may be able to send you a replacement. Hope your printer is still within warranty. Clear it from foreign objects. If not making any noise, re-insert the cartridges. If noise starts again, it may be caused by the cartridges not being seated properly. These are the troubleshooting steps you can do to determine what the problem is. If none of these resolves the problem. I advise you to call Lexmark. Hope I can assist you more with this. Good luck!
Open Printers by clicking the Start button, clicking Control Panel, clicking Hardware and Sound, and then clicking Printers. Click Add a printer.In the Add Printer Wizard, select Add a local printer.On the Choose a printer port page, make sure that the Use an existing port option button and the recommended printer port are selected, and then click Next.On the Install the printer driver page, select the printer manufacturer and model, and then click Next.Complete the additional steps in the wizard, and then click Finish.
X6650 it doesn't the clicking nosies stops when i unplug power brick
Hello. What is the exact model of your printer (e.g. X6650, X7675, X9575, etc.)? When does this clicking sound happen, when printing, copying, scanning or faxing? Or does this happen when printer is powering on?
I have the same problem. It is the little gear that turns to move the scanner back and forth. It seems like the band is loose. How can I tighten it or replace it. I need to be able to open it up to get to it and have no idea how.
