The red light on the front is part of the system control (computer) in your television it indicates likely your power supply and computer are functioning. There are a multitude of problems that can cause no picture and no sound. Power supply troubles are most likely. The system control will have it's own little power supply which is always on so it can listen to the front panel or your remote. It will continue to operate when the heavy duty power supply might not. This suggests a shop repair would be in order. House calls can't fix something like this unless they are VERY lucky and find something obvious. You will still pay for the house call even if they can't fix it.
SOURCE: Sony KP-51HW40 No Picture, only sound
how many thimes does the light blink, it's an indication as to where you should start looking for the cause of the problem
SOURCE: standby/timer light stays on red. no picture or sound on tv.
my sony red light flash.but it will not turn on just clicks
SOURCE: WD-52631 Red Light-No Picture, still have Sound
unplug it from the wall, wait 30 seconds, then plug it back in. i had the same problem and this simple solution worked for me. Good Luck!!!!
