SOURCE: How do I erase the memory from my Sharp UX B700 Plain Paper Inkjet Fax
chose from setup menu on fax erase document in memory or etc.
SOURCE: sharp ux-b700
do you hear the tires trying to pull the paper? if yes clean with alcohol ( may be slipping)
SOURCE: Sharp UX-184 Paper Feed
On inside of machine it states how to:
1. Place new paper roll on the left hub while pushing it in, lowering the roll into the compartment making sure it is inserted onto the right hub.
2. Pass the leading edge of the paper through the paper cutter guide and the cutter.
3. Remove any slack in the paper.
4. Close the cover. The paper will feed out automatically.
The paper rolls over top front to back.
Here is your solution
» Brother
» Canon
» HP
» Lexmark
» Panasonic
» Samsung
» Sharp
» Other
a
