Timex (T307S) Clock Radio Logo
Posted on Mar 14, 2008
Timex clock radio dst feature
Is the timex T307 DST feature set up for the 'new' EPAct 2005 DST or should I turn the DST feature off so it doesn't change at the wrong time?
  • 1 more comment
  • Flash66 Apr 07, 2008
    Same problem, different model.
  • Anonymous Mar 20, 2014
    Cannot reset dst or actual time
  • Anonymous Mar 25, 2014
    I was having difficulty changing to DST, now that is fixed, but the time is 20 mins fast
Anonymous
Level 1:
  • Contributor 2 Answers
  • Posted on Apr 23, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
1977
Points
Here's a link to a photobucket album of the manual i scanned for the Timex T307R.
the pics are not pristine, but you can still read them.
http://s120.photobucket.com/albums/o188/ec1000/Timex%20Manual/
i hope this helps everybody, i know that unfortunately Timex cannot help at all by actually putting the damn manual on the internet.
peace.
How can I set the time zone?
The DST is only based on GMT.
When daylight saving time (summer time) begins
The following models employ the Automatic Daylight Saving Time/Summer Time adjustment. The DST indicator in the display appears in the display at the beginning of the daylight saving time (summer time), and disappears at the end of it. Automatic DST/Summer Time adjustment is based on GMT (Greenwich Mean Time).
• Summer time begins at: 1:00 AM on the final Sunday of March.
• Standard time begins at: 2:00 AM on the final Sunday of October
To cancel the Automatic DST/ Summer Time adjustment and
to set DST display manually
The Automatic DST/Summer Time adjustment can be cancelled.
Press and hold DST for more than 3 seconds while the clock is displayed.
A beep sounds, and "Aut t OFF" appears in the display to show that the Automatic DST/Summer Time adjustment is cancelled. The display returns to the clock.
Notes
• The change timing of Automatic DST/Summer Time adjustment employed by the unit (see above) is subjected to variation by circumstances and the law in each country/region. In such a case, cancel the Automatic DST/Summer Time adjustment and
set DST display manually as necessary. The customer who lives in the country/region that has not introduced the daylight saving time (summer time) must cancel Automatic DST/Summer Time adjustment before using the set.
• To activate the Automatic DST/Summer Time adjustment again, press and hold DST for more than 3 seconds. A beep sounds, and "Aut t On" appears in the display to show that the Automatic DST/
Summer Time adjustment is activated. The display returns to the clock.
• To change the display to the daylight saving time (summer time) manually, see "To change the display to the daylight saving time (summer time) indication."
Sony ICF ICF C318 Operating Instructions Operating The Radio Setting The...
2helpful
Daylight savings time changes at wrong date on my brookstone 'smartset' alarm clock. (It changes at the old date, of course - so it is wrong 4 times a year...)
The DST schedule is hardwired into the older clocks and cannot be modified to run on the new schedule. If the clock has a DST switch, you can can turn it OFF and reset the clock only twice a year. On my old "ATOMIC" clock, I've set the DST function OFF, and I use the time zone switch for my adjustments. Sorry, but your only other choice is a new clock.
Bill B
2helpful
Need to update daylight savings time date
This is from the Timex FAQs site:
Q: My clock did not update for DST.
A: We apologize but there is no patch available. Consumers must change clocks manually. Due to newly enacted government regulations, effective this year you must change the time manually, since the calendar was programmed to change according to the time DST issued by the government, it will not recognize the change after 2007. Now the time must be changed 4 times. Press & hold the time set button until the time flash, then release it and press the ff >> or << rev buttons.
1helpful
How do I disable the Daylight Savings Time function? the dates for DST have changed and the alarm is still set to the old date changes.
See the comments under Petewete. There is no way to disable it on the T301B model. Changing time zones doesn't help because all 7 zones observe DST, or at least they did before 2005. (Now Hawaii Zone 7 does not). I know because I tested all zones. The workaround is complicated: before each time change, pretend it is the old DST date (1st Sunday in April or last Sunday in October) by resetting your date. My spouse says to fix the problem by hitting the snooze button with a 20-pound sledge hammer.
3helpful
2answers
How to reset Emerson SmartSet AC100 Alarm/Radio for DST changes!!
No way to change it to automatically do it without replacing the data chip. I changed the time zone from 3 to 2 in the fall and then have to switch back to zone 3 in April.
2answers
RCA atomic clock radio didn't reset to DST
Perhaps you've already tried this but on my atomic clock I have to select the DST option and make sure you're in the correct time zone.
3helpful
5answers
Daylight saving time auto change over
call 18006954820 they will walk you through
2helpful
3answers
Turning daylight saving time OFF
If DST is *already* set to "on" when you reset the time zone to Z-07 (Hawaii), my very recent experience is that the time *still gets adjusted back* by one hour.  Now that daylight savings time is over (at least according to the clock's pre-programmed and outdated schedule) I'm hoping that setting the time zone to Z-07 (Hawaii) will completely cancel the automatic time changes from now on.  Otherwise, I need to purchase another clock, and it won't be a Timex.
Clock will not change to new DST time
You should visit this page: http://www.fox-international.com/emerson/ It contains information for identifying the specific DST fix for your model.
16helpful
5answers
Timex T301B
Petewete,
Here is the manual.
http://www.timexaudio.com/pdf/T301IBOnline57204_83.pdf
Frank081541,
You can't adjust the Daylight Savings Time. I called Timex and they confirmed this.
Top Timex Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Are you a Timex Audio Player and Recorder Expert? Answer questions, earn points and help others
