If the laptop battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced.
you have to make sure the player is off when ur charging it. or you can listen to it while its charging to make sure its not playing and charging at the same time. i had the same problem too. so just keep the ear phones plugged in and make sure its not playing while charging. and keep it turned off while charging. and you should be good. it will them play for like 1 to 2 hours. you might be thinking how can you turn it off and it still charges. but once the red light is on that means the computer regonizes it and its charging. good luck. facebook.com/kedisha queen-king
Most likely you have a full charge but the problem is FALSE Advertising! Swagger MP3 players only support MP3's downloaded from Amazon.com, any other MP3's will only play for a matter of seconds before shutting off. These players are a total rip off.
that`s not the reason.your Ipod have some problem with the firmware.connect your ipod to itunes and select reset.make sure you reset through itunes.you`ll lose songs on the ipod but it will work.
Sounds like your battery may be at fault, or if you rely on the usb to charge, then maybe it's not charging it due to power settings on the pc. Try charging from the mains without the player being turned on, for about 20-30 mins. Then turn on and if the problem is still there, then it's the battery.
I have the same problem, not the same mp3 player, but it just randomly stops
