Do it carefully..at your own risk..
HP 496771-001 Keyboard Repair and ReplacementAre you considering
laptop keyboard
repair? You might think twice if you happen to be the lucky owner of a
laptop, because replacing the keyboard rather than repairing it could be
a lot less expensive.
Laptop keyboard
replacement on this particular model is very easy and takes just a few
minutes. Here is a quick HP 496771-001 Keyboard repair tutorial with
step-by-step instructions.
Once you have purchased the new
keyboard,
all you need to replace the old with the new is a screwdriver and
something plastic, flat and thin like a credit card or guitar pick.
Step one:
Remove the two screws from the bottom of the computer that are holding
down the HP 496771-001 Keyboard bezel. The bezel is the bar that sits
right above all the function keys.
Step two: Turn
the computer over, open the cover and insert the credit card or guitar
pick between the bezel and the laptop screen. The bezel has pegs that
sit in holes, you need to slowly pry up the bezel. It will make a bit of
a popping noise as it is removed.
Step three: Now hold on to the
laptop keyboard
from the end closest to the screen and gently pull it away from the
touch-pad end and flip it over. You will see the ribbon attached to the
underside of the HP 496771-001 Keyboard. There is a little plastic
connector holding the ribbon to the computer. To unlock it, carefully
pull up on the two tabs; one located on each corner of the connector. Be
very gentle when you do this as this is the one part that gets broken
the most often when changing a keyboard. The ribbon cable will now be
released.
Step four: Carefully pull the ribbon out of the connector and remove it along with the entire
HP laptop keyboard.Final step:
To insert the new HP 496771-001 Keyboard, place the board face down so
you have easy access to the ribbon. Make sure the keyboard is lined up
so when you flip it back over the keys are in the correct position. Keep
the ribbon straight at all times; twisting it could damage it. Place
the ribbon in the connector; it only goes in one way. Once in place,
push down on the connector tabs to lock it. Now flip the keyboard over
and slide it down toward the touch pad and take the bezel and line the
pegs up with the holes and push it in place. Then turn the computer over
and replace the two screws you removed from the bottom. You can now
power on your computer and see if the HP 496771-001 Keyboard works. If
it is not working, more than likely the ribbon was not inserted
properly.
Regards,
Ron
