With the camera turned on in the mode to take pictures, press the top of the 4-way controller (lightning bolt) and you will see an icon come up on the LCD. Press the controller again until you see a lightning bolt with the barred circle around it (no flash). The flash options may not be available in some SCN (scene) modes, so use AUTO or P, if possible. Turning the flash off is a setting that is not remembered when the camera is turned off -- you have to set it each time you turn the camera on.
Press the Flash button (the top part of the circular "joystick" button, marked with a lightning bolt) to cycle through the options. You can choose from Auto with red-eye reduction, Auto, Flash on with red-eye reduction, Flash on, and Flash off. You want the lightning bolt in a circle with a slash through it.
Testimonial: "Very helpful and fast response. Thanks"
SOURCE: cannon A530 want take picture ,come on everything work want sh
CCD FAILURE!
Call canon for Free Repairs it is a known manufac
fault in thousands of cameras , dont worry just call them see this for
info on this problem
Kindly Rate me WELL !
Service Advisory Link this applies to all products with same problem dont worry u r included just call them and tell them abt BAD CCD !
Good Luck !
SOURCE: When Turning on the Canon Power Shot A530 the
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here are some things that you can do to try to correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty, or if repair costs close to the value of the camera, they're worth a try.
