GE 1800XL undercounter microwave. changed light blub under micro sparked, blew circut breaker, reset time no light inside microwave no power nothing but fan works, power boast works, but not heating not turning on.
Hello :
It could be bad door switch or loose door switch mount . There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
or it could be problem with the control panel .
good luck .
please rate !
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Blubs blew out new ones won't come on fan works inside blub works
