It means your Blackberry is already unlocked . You do not need to unlock it again.
http://expressunlockcodes.com
Follow this instruction to enter your blackberry storm 9530 unlock code :
1. Power ON your BlackBerry Storm 9530 with any SIM Card.
2. Scroll and select Manage Connections.
3. Select Turn All Connections OFF.
4. Press Escape to go back to the Home Screen.
5. Go to Options menu and select Advanced Options.
6. Click on SIM Card.
7. Click on Show keyboard.
8. Hold the ALT key while typing MEPD. You will not see text appear on screen while typing. This opens up a personalization menu.
9. Hold the ALT key while typing MEP2. You will not see text appear on screen while typing.
10. Press ALT and 2 simultaneously to get number 2.
11. You should be presented with a prompt Enter Network MEP Code.
12. Enter your blackberry unlock code.
Before you start, you MUST have an
Unauthorized Sim
Card inserted. An unauthorized Sim Card is a
Sim Card that is NOT belong
to the
provider of the phone. Example: If you have a Verizon phone, you
need to insert a T-Mobile Sim Card inside
the phone
before turn it on.
1. Power
on the phone.
2. Phone
will said "MEP check failed. Do you want to
enter MEP unlock code". Select Yes.
3. "Enter
Network MEP code (# left)". Enter the unlock code.
4. Press
Enter, you should see “Code Accepted”
5. You
need to check Network Connection is set on GSM/UMTS. Menu>Manage
Connection>Mobile Network Options and make sure it GSM/UMTS.
6. Once
GSM/UMTS is selected. You can now ready to make phone call.
Notice:
If the network not working after your phone is fully charged and
unlocking
process “Code Accepted”. You must change
from
Verizon CDMA network to GSM Global Network a few times, after change
from
Verizon CDMA to GSM Global 3 times is completed, leaves it on GSM Global
Network. Now it should work. (Verizon 8830 World Edition DOES NOT work
in
USA)
