Words appear on screen but not picture, it was hit by lightning, is there a reset button? is there a way I can check to see if both tuners are bad? it is a Toshiba 36A61
SOURCE: picture is ok hissing sound in rf connectoin
Yes, change the tuner and make sure that all ground are well connected.
SOURCE: Toshiba 36A61 TV Deglaussing Problems
DEGAUSS IS INTERNAL AND ONLY WORKS WHEN THE SET IS FIRST TURNED ON. YOU WILL HAVE TO OPEN THE SET AND EITHER SOLDER THE BURNT CONNECTION OR REPLACE THE THERMISTOR. THE DEGAUSSING COIL GOES AROUND THE OUTSIDE OF THE TUBE(INSIDE THE SET) 2 LEADS AND PLUGS IN CLOSE TO THE AC LINE CORD. IT IS CONNECTED THREW A TEMPERATURE COMPENSATING RESISTOR THREW A RELAY DIRECTLY TO THE A.C. LINE INPUT FOR ABOUT 2 SECONDS WHEN THE SET IS FIRST TURNED ON.
