I have the Kitchenaid Professional 600 stand mixer. It's about 3 years old. I tried mixing pasta dough and notice the mixer head loose. Is there a way to tighten it up -- would like to know how to get to the screws holding the head to the base. Thanks!
Remove the screw, item 22, to remove the trim band around the mixer. This will reveal 4 screws which hold the top cover on. Remove the screws and lift the top off. Find all the screws which hold the gearhead in place and tighten them all. If you want to make the fix a permanent one put some thread-loc compound on each screw and tighten it.
Is there a similar procedure for the artisan 4.8L? I have a ksm175 with the same sort of problem, whereby the actual beater shaft - the part that holds the beaters - kind of bobs up and down, especially noticeable when I use the flex edge beater and it makes a hell of a racket :/Is there a similar procedure for the artisan 4.8L? I have a ksm175 with the same sort of problem, whereby the actual beater shaft - the part that holds the beaters - kind of bobs up and down, especially noticeable when I use the flex edge beater and it makes a hell of a racket :/
You can't post conmments that contain an email address.
This is an excellent mixer and worthy of a professional or DIY repair.. You stripped a gear inside the mixer that is there just for that reason. Now the machine requires a tear down and replacement part. if you can post the model number we can advise on how to do it. If it is the new pro series model they cost between 4 and 5 hundred new to buy, the repair is going to cost between 80 and 100 dollars by a professional or about 30 dollars by you.
Let it completely cool and then start again. It overheated because your speed was set too low for the heaviness of the dough. I have burned up three kitchenaid stand mixers so far making bread. go up one setting at least; if it is straining, go up another.
You can knead longer than that, but you run the risk of over heating the mixer because at that point the dough is very firm. Your best bet is to knead it by hand.
the solution to this is to tighten the screw visible through the base that intersects the pin. Turn the machine upside down and using a long flat screwdriver tighten the screw.
it is hard to tell you exactly what it could be, but a common problem is after a while the transmission gasket does deteriorate and will begin to leak oil.the gasket is part number4162324. the rattling noise inside your unit is most likely cause by a chipped gear inside, this can happen when the unit is put under heavy loads, such as dough. this problem could get worse as there may be fragments inside that will damage it more.hope this helps
The Professional 600 has a metal gear housing with a metal gearing. Because of this, the Professional 600 will generally run louder than other stand mixers that may have a nylon/metal mesh gearing.
How long is the bread dough being mixed for? Kitchenaid stand mixers must be used on speed 2 for bread doughs, using the spiral shaped dough hook, and mixing for no longer than 7 minutes.
If the flat beater is getting caught on the bottom of the bowl, pleasure assure the bowl is being seated correctly. You will place the bowl on the mixer arms on the left and right hand side. You will also want to take your fingers along the back of the bowl, where it butts up against the base of the mixer, and press downward. You will hear an audible click as the bowl falls into a spring latch and allows the bowl to sit flush and secure. If this is not being done, the flat beater may strike the bottom of the bowl.
If this was not the cause of the problem, please consult your Use and Care Guide about the beater to bowl adjustment. This is an easy adjustment made with a flat head screwdriver that can quickly correct the problem of a flat beater hitting the bottom of the bowl.
They give only one year warranty. But these devices are not so complicated.
Have the right handy guy a look at it. You know anybody on the block?
Else you have to go to a repair shop. Diagnozing her from here is undo-able.
And still not fixed over there. I think it is a small thing.
Hi. Stop using your mixer. If your mixer is still covered by warranty, call Kitchenaid Customer Service, they are very good with warranty repairs.
If your mixer is out of warranty, remove the silver band that surrounds the top of mixer. Remove the top cover. At the front of the mixer, locate the transmission housing which is now exposed. Examine this housing carefully for cracks. If you find cracks anywhere in this housing, you have found the under-engineered plastic transmission housing. Kitchenaid's replacement housing is made of metal. Your plastic housing has no business being in a mixer that is marketed as being able to mix bread dough. It cannot!
If you're confident that you can make the repairs yourself, go to the Kitchenaid website and download the parts drawings. Remove the Trans. housing, remove the worm gear shaft assembly which is driven by the motor.. Remove and save as much grease as necessary to thoroughly inspect the worm gear. Inspect the worm shaft bearings. Look for cracks, or missing pieces on the bearings. Look for crunched cogs on all gears. Be prepared to wait at least a month for your parts to arrive after you order them. The replacement grease should be Shell Darina 2, or Chevron FM ALC EP 2.
If you're not confident about repairing this yourself, call Kitchenaid and determine the nearest "approved" repair shop.
You may be able to pressure Kitchenaid to pay for the damaged parts in your mixer. They are still installing these plastic Trans. housing on new mixers. Insist on a metal cover when replacing. Apparently, Kitchenaid feels no shame in their manufacturing process, and will not issue a recall notice for these housings. They are substandard at best.
If you found this solution helpful, please rate it. Good luck! ricardok45.
