Re: Speed queen Marathon top loading washer- Water leaks...
The problem is the water inlet valve has failed. There is a video on checking this at www.appliancehelponline.com/servicemanual.html it's a different model but the testing procedure will be the same.
A Speed Queen top-load washer making a banging sound at the beginning of the cycle could be a sign of a few problems. You could examine the following:
Size of load: Check to see that you are not overfilling the washer. The water and clothes should be about 3/4 full in the washer. Overloading the washer can result in the drum becoming unbalanced and making banging sounds.
Leveling: Verify that the washer is level. If not, reposition the washer's feet until it is level. A washer that is out of balance can also make banging sounds.
Spring elements: Examine the suspension springs at the drum's top. The drum may slam against the washer's sides if one of them has broken or come loose.
Motor: The motor might be the source of the banging sound. The washer may vibrate and make banging sounds if the motor is loose or damaged.
The to ensure that the water valves at the inlets are fully open. If they are, then shut them off and remove the hoses from the supply to the washer. There is usually a small metal screen-type filter in the connection at the back of the washer for each hose. These may be clogging up. They can be carefully removed, cleaned, and reinstalled.
try checking the where the water hoses connect that water valve is where the water is shut off, turn off the water facuet undue the hoses and look inside the valve does it have calcium buildup? or sand in it? if it does you will have to pull the water valve to clean it in order to get it to work correctly. Let me know if you need more help and thanks for using fix-ya.
Pi,r,squared times height. Remember math back when we didn't have computers? So that's 3.14 x radius(half the distance across drum)squared(times itself) times height or depth of drum. Remember to do radius times itself first, then Pi, then height.
Hi, just fixed the daughters speed queen, same problem. The three brake shoes were worn allowing the tub to spin with the agitator.
replaced the shoes, washer fine. At first I thought it was the top ring. spent 30 dollars for nothing.
good luck
It sound like you drain hose is siphoning off the rinse water, It needs a standpipe make sure the drain hose is at about the height of the top of the washer, Make sure the drain hose isnt stuck in the drain it also needs an air cap. the drain hose should not lay on the floor to run to the drain
Please let me know if this doesnt solve your problems
