Hello, I have a Tru GDM-47 cooler and the evaporator keeps icing up in back due to the compressor not cycling. It has a brand new compressor and if we turn the thermostat down, we can get the cooler to go down to the 20's Fahrenheit, but even set at a warm temp, the evaporator ices up.
Possible bad defrost timer,or control on an off is bad,were you adjust temperature...thermostat from 30 to 65.00 dollars....possible there is leak or unit is under or overcharged..more than likely under charged...possible defrost heater is not working...good luck..michael doctor airr appl.repair..service tech..843-384-8474...call if need additional help ..its free..
