To cook rice, fill center basin of base with water. Place the rice bowl
on basin. Add rice and water as follows. For white rice add water in a
1:1 ratio to rice plus 1/2 cup. For brown rice add water in a 1:1 ratio
to rice plus 3/4 cup. Examples: 1 cup white rice, 1-1/2 cup water; 2
cups brown rice, 2-3/4 cups water. Put lid on and plug in and in about
50 minutes you should have delicious rice.
Please rate this answer. Thank you.
SOURCE: Need instructions for National Rice-O-Mat Rice Cooker SR 10GHN
You can just go to a web site and look search for Rice Cooker Steamer. And find some important information.
SOURCE: Rice Cooker Instructions
if cooking rice is your problem. you must first fill your rice cooker with rice and rinse it with water to remove excess starch when your done removing the excess starch you will have to add water for every cup of rice, 1 1/2 cups water or you can try 1:2 ratio (1 cup of rice: 2 cups of water). same goes to any other cuisines. i hope you find my solution helpful.
SOURCE: Lost the plastic measuring cup for rice cooker/steamer
How many cups of rice did you use compared to water. Use the same number, using anything from a teaspoon to a small soda bottle. The rice doesn't really care how it gets measured.
SOURCE: lost the measuring cup for 10-cup rice cooker and
1 cup rice and 2 3/4 cups water
makes about 4 cups rice.
SO:
2 cups rice and 5 1/2 cups water should do it.
SOURCE: elite 3 cup rice cooker-need instructions for cooking rice
If you go on this website you can download the manual from the manufacturer of this rice cooker.
www.maxi-matic.com/product.php?productid=48&cat
Regards
Alan Hood
ami-man
UK
Testimonial: "GReat! Thank you so much I will try it right now :)"
Here
is a tip that will help you figure out about using a rice
cooker...
How
much Rice and Water go in the Cooker
heatman101
