Hoshizaki Cubelet Ice MakerDispenser Water Cooled LED Sensor Operation Logo
Posted on Mar 27, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I need to obtain DCM-240BAF Hoshizaki ice machine service manual. I bought this ice machine used through ebay. It was working fine and now no ice is coming our the bin looks clean, but I do not want to spend a fortune on a tech coming in, and I would like to obtain a manual for the the machine hopefully to figure out what is wrong
Marat Brikov
Level 3:
Director Badge:
Uploaded 100 video answers.
  • Hoshizaki Master 518 Answers
  • Posted on Oct 09, 2015
Marat Brikov
Hoshizaki Master
Level 3:
Director Badge:
Answers
518
Questions
0
Helped
324359
Points
3123
Dennis Boxerman
Level 3:
  • Hoshizaki Master 1,306 Answers
  • Posted on Jul 11, 2010
Dennis Boxerman
Hoshizaki Master
Level 3:
Answers
1306
Questions
Helped
646546
Points
2787
Http://www.hoshizakiamerica.com/manuals/DCM-240BAF_serv.pdf
check out this site. It should be your manual that you want.
Let me know if I can help get it going.
2answers
Hoshizaki AM-50BAE ice machine quit making ice-could hear water running through. Bad odor. Repairman determined it was pump- new w/installation was going to be 600+. Advised to pu
If you want the ice maker work. you will to pay for the repair, If you want you cam another company.. Or you can do nothing which is nothing
Hoshizaki ice machine manual
patulong aman po kung pano mag hard reset sa d5 torque
Hoshizaki dcm 500 freezing up suction line
This calls for a tech that is familiar with this stuff. I have one a work and it runs great but I can't fix me. There several things it could be. Is it waking water anywhere. And does it run constantly.
Hoshizaki M# DCM-270BAH-OS runs for days then freezes up evap coil and stops water inlet to evap.
There is a thermostat probe sat on the front of the evaporator to tell the control board when to harvest. Check it is tight in it's holder. Check the condenser is absolutely clean and filters clear. You can adjust the thickness of the cube. set it on the thinnest setting and see if it harvests before freezing solid.
Hoshizaki ice machine model KM-250BAF SERVICE MANUAL
km-450mwb hoshizaki problem is machine strate is ok but to long time ice making , not dropping, two beeps every three seconds what problem i don't no pleas help mi
7helpful
5answers
Beeping Ice Machine
I have a Hoshizaki KM-250BAF that is making 3 beeps then pauses and them makes 3 beeps again. If I unplug the ice maker and plug it in it continues to make the 3 beeps. The manual does not mention anything about beeps. Can anyone help?
Hoshizaki Ice Maker
check condenser condition can be dirty, cleaning the coils with coil cleaner for ice machines(i suggest you take all the ice out of bin first) i'd go with that first. check if it works for you.
1helpful
Water works fine - No Ice
Does it sound like everything is running, only the machine isnt makinf ice? If so, there is a small triangular housing with a hose connected to the small motor on the left under the front panel. shut off the machine and remove the 3 screws on the triangular housing. inside there is a spring and a round rubber disk. take these items out and clean them. its amazing a tiny amount of debris will cause this to not work. install the reverse as you removed thewm, turn the power on.
Top Hoshizaki Kitchen Appliances - Others Experts
Kolbrun...
ADMIN Andrew
ADMIN Andrew
Thomas Perkins
Thomas Perkins
Are you a Hoshizaki Kitchen Appliances - Other Expert? Answer questions, earn points and help others
