hi,
most of the time we are putting a password in our memory card so that
the others cannot view the important and sometimes the confidential
files..but unfortunately we forget it so what we are going to do if we
cannot open our memory card?if we are going to a cellphone shop we are
spending much money ,if we buy a new one we also spend ...
i want to share how to unlock/ removed password in your memory card
micro sd...this is applicable only for the card like MINI SD(this is
bigger than micro sd and used in nokia phone like n73 ,n80 ) and for
MICRO SD (used in nokia E-series ,classic nokia like 3500c ,6300 ,3110c
,7210c etc and other chinaphone )...
tools you need is high end phone like nokia 5800 ,n95 ,e63 ,e71 etc...(for phone using mini sd like n73 you need an adaptor..
here is how.. 1. insert your micro sd at nokia 5800 , memory card password will appear just cancel it..
2. go to menu,applications then file manager then you will see that memory card is locked..
3.open memory card you will see memory card locked
4. press options >memory card options and format memory card will appear
5. wait until formatting is finished
6.you will now rename the memory card and the password is gone...
note: in this process all your data will be lost but but you have no choice because no other way to removed your password than this...
i hope it will help you ,thanks for trusting fixya
just update ur fone firmware OR hard format ur n73... by following method:
(note : b4 u do any of the above solution remove the password of memory card and also take the backup of ur memory card through Nokia pc suite not by using cardreaders....)
hard format :
remove memory card
switch off the fone
now press call key(green) + 3 + * key
keep on pressing all three keys and switch on the fone ... dont release the keys untill the fone boots on....
the fone settings will be restored to its default... also all d security codes of fone will be retored to defaults....
now ur problem is solved .... put ur memory card back.... n if it still asks for memory card unlock password ... then jus format it .....through fone..... it wont ask again.....
Try removing your memory card and then using the phone.
If this solves the problem, then might be your phone is unable to deal with the amount of data stored on your memory card.
OR
Remove applications like 'FS caller' and applications that eat resources of your phone.
