Question about Crown XTi 4000 Amplifier
Fan don't work when power is turn on crown xti 4000
    New Friend:
The fans on these amps are heat sensitive, only when the amp heats up, then they come on
Posted on Jun 25, 2013
    New Friend:
I have XTi6000 same time work same time not work when the work display screen not show but LED graphic work fan work LED power not work and input audio Not work. how fix it I need you help me.
Posted on Jan 15, 2013
  • 1,527 Answers
Hello try and get another fan strip the wires and where the fan is connected place there. and turn if the fan spins the you need a new fan if it don't spin then the fan fuse may have blown
regards
shaun
Posted on Mar 27, 2010
John McPherson
  • 1212 Answers
SOURCE: my amp was blinking while it was working then it went off.Now it doesn't power up..Crown Xti 4000
Power supply likely failed. Electrolytics are the primary culprit.
It should have a switchmode power supply, so it is lmost likely the 5 volt section failed.
Posted on Sep 27, 2012
When I on my xti crown 4002 power amps,why the fan is not on,please help me,It just new after 3 days now..
Is the fan supposed to be on. On some units it runs all the time on others when the temp hits a certail level. Which is it for your baby?
Sep 03, 2017 | Crown Audio Players & Recorders
I need crown iT4000 semantic
Schematics are easy to find, just enter: schematic crown it4000 in the Google search engine. I cannot find any semantic
Nov 04, 2014 | Crown XTi 4000 Amplifier
Crown xti short1
details? what is short1?
Apr 21, 2014 | Crown XTi 4000 Amplifier
My xti 6002 crown amplifier ch2 shows thermal protect and fan is in full speed .what is causing the problem kindly give some tips to repair it
Crown utilizes small signal transistors as thermal tracking devices but i think that this is not the main issue with the amplifier, it could be in the output stage with some power transistors failure, does the other channel works fine?
Oct 11, 2013 | Crown XTi 6002 1200w Stereo Power...
My amp was blinking while it was working then it went off.Now it doesn't power up..Crown Xti 4000
Sep 17, 2012 | Crown XTi 4000 Amplifier
Dsp off
Try here:
http://www.crownaudio.com/express.htm
Mar 22, 2010 | Crown XTi 4000 Amplifier
Crown XTi 4000 brand new digital amp how can i unlock it? i dont know but the screen display short 1
Hiya, to unlock press PREV and NEXT until it says unlocked.
The short 1 sounds a little serious though. Have you tried taking off the speakers?? If still there then suggest contacting crown. They have a pretty good no nonsense 3 year warranty
Best of luck
Jul 13, 2009 | Crown XTi 4000 Amplifier
Crown XTi 4000 Amplifier Logo
698 people viewed this question
Top Crown Audio Players & Recorders Experts
 Grubhead
Grubhead
Rob Beech
Are you a Crown Audio Player and Recorder Expert? Answer questions, earn points and help others
