I've managed to come across this from someone who called microsoft with the same problem (it seems quite common)
Go into settingsConsole settingsThen device settings (The one with the blue screen) Then go: left trigger, right trigger, x, y, left bumper, right bumper, left with left stick, up with left stick, right with left stick, x
If you have trouble use the pad instead of stick, but I could only get the stick to work..
Does it say things like, Searching for match? When I first started playing it did that alot. But eventually you get into a game. And you must beat the Campaign to be able to play Nazi Zombies.
Managing Xbox LIVE Activity Xbox LIVE Controls come into play only when you take Xbox 360 online, and they're linked to a child's profile and gamertag. When an Xbox LIVE account is created, the service asks for the member’s age to determine whether to apply Family Settings to that account. Parents are also required to create or use an existing Windows Live ID. The Windows Live ID is associated with the child’s Xbox LIVE account and protects the settings from being changed later by the child. To change a child’s settings, first select the child’s account name and connect to Xbox LIVE. Once signed in, enter your Windows Live ID password to unlock the settings. To see these controls, go to My Xbox, open System Settings, then selectFamily Settings, Xbox LIVE Controls.
One red light means either the hard drive isn't connected properly, or the video cable isn't connected properly, or is damaged.
Check the hard drive, and the video connection to ensure they're in there tight.
The xbox 360 wirless controller has very little lag that you would not be able to notice i would suggest just getting the controller and if u want u can also get a xbox 360 controller that is wired.
oh okay, tell him to check the connection of his a/v cable. possible causes could be that the cord isn't securely connected to the system at the back.
also, be sure that the switch on the end of the cable is set to either a/v or component (high definition R G B) depending on which one he's using! i hope that helps =)
