No because it is too dangerous. When you go into Airplane Mode, you literally turn everything off! Airplane Mode is only for being on an airplane. If you are using it a lot whilst not flying, you are not using it correctly.
Go to the phone main menu, select settings, and look for Airplane mode, press it. It should give you the choice of turning it on or off. Select off and you should be able to call and receive calls again.
go to the sound profiles in side the settings on that you will see a profile named as offline. click on it and activate it. its the airplane mode in the samsung
If you want to try a simple solution, Go to Settings, Wireless and Networks, then Turn on "Airplane Mode" wait until you see an airplane on the top status bar of your phone... then Turn OFF "Airplane mode" If that doesn't work, and you want to reset your phone, take it to the place you bought it or any place that is on your carrier.
To fix the problem and restore your connection
(turn OFF airplane mode), click "Menu," then "Settings," then "Phone
Settings," then "Airplane Mode," and then set the mode to "Off." Once
you turn off the airplane mode, your Samsung phone will function as
normal.
