Konica Minolta Dimage 7 delay in start up and shot down procedure
I have a Minolta Dimage 7 Digital Camera SN91202050.
I'm very keen in electronics and I have its service manual (45 pages).
Few months ago, I upgraded the firmware to ver 2.01e. (Iread the full compatebility notice before installing).
The camera worked so fine.
I've got about 2000 jpgs
And the last day I took about 200 jpgs in a very short period of time. So I was enforced to exchange the batteries during the snapshots. I'm using 2500mAh MiMH Kodak batteries. I noticed that the grey front right hand part of the camera is a little bit overheated.
The next day, and after the camera returned to its normal temperature, I tried turning the Main Switch/ Mode Dial from OFF to Recording Mode, after putting a completely charged batteries.
Unfortunately, I heard a small sound "Tick" then nothing happened else, the Data panel stayed dim(unlit) and with no data, and no red indicator had seen, also the monitor LCD didn't start. I didn't hear the noises which the camera should give in normal conditions.
I left the switch as is, few minutes later, the camera continued the startup procedure, as I heard the noises and the Data panel lit in green and it displayed the normal status.
I made several snapshots and everything were going well.
I turned the **** to playback mode, I have seen the entire snapshots I did.
Which mean tha the CF card is working well.
Also all the other knobs were working properly.
Then I decided to turn the camera OFF.
Again, the LCD monitor turned OFF directly, but the upper Data Panel was left ON!!! And I heard "tick"
Few minutes later, it turned OFF automatically. And I heard the same noises in the normal manner.
1-Does that mean the main board had a cold welding point? Or, the board was affected in the earlier overheating.
I tried to use the transformer instead of the internal batteries, and I found this same situation. Delay in the turn on and turn off. And also the delay period is the same.
2-Does that mean that some chemical capacitors were damaged? ( wich capacitor should I replace?).
3- Does that mean there is a cold welding in some points beyond the processor in the MAIN PCB ASSY(0402) due to the frequent humidity and overheating?
N.B I tested the internal backup battery, and it gave 3.24V (it's ok)
I also have had a similar problem. I have a Minolta Diamage 7i, the camera is 4 years old, I use it quite regularly. I used the camera to take photos with and then packed it away. The next day I went to use it and the camera would not turn on. Mine did not make a clicking noise at all, it seemed to me like it was completely dead. At first I thought it might be faulty batteries, so I recharged my new panasonic batteries and tried it again. I got the same result, then I tried brand new Duracell batteries, again, the camera did not switch on. I then thought it might be an internal fuse of some sort. However, I left the camera switch in the on position and 3 minute or so later the camera switched on. I could take photos as normal, downloaded them as normal. I then thought the camera might have a humidity shut down built into the circuitry. so I left it on for 10 minutes and then turned it off again. But when I tried to turn it on, it did the same thing again. If I leave the camera in the on position it eventually turns on. The on times vary anywhere from 3 to 6 minutes.
Except for this problem the camera otherwise works great. I'm thinking that it could be a dry or leaky capacitors or a capacitor related problem, I can't be certain without a circuit diagram. I am a Radio Tech by trade, so if anyone out there can help me with this matter it would be much appreciated.
Thanks
Avo Hi there,
Thanks Avo
You can't post conmments that contain an email address.
I have exactly the same problem, I'm guessing that the flash capacitor has died.
I'm using the camera for outdoor work only at the moment, when I get desperate I might try taking the top off to see if I can find the capacitor.
Hi the problem your having is that a component on the board isnt letting the correct power come from the battery therefore giving false reading on the batt display the huge problem you have is that they dont repair these cameras it just isnt financially worth it so unless you know how to test all components on the board the chances of getting it reapired are slim to none their isnt anything you can do as it is a board problem. If you tested the battery and this is fine then the problem is deffinately with the board. How long have you had the camera if its not long then i would get a refund as repairing is something they wont do sorry i couldnt help you any more but other experts will tell you the same
It sounds like a short in the circuit board. Not worth getting fixed unless you find a local person. but first try puting a set of lithium batteries in. sometimes those last forever even when other batteries last less than 10 shots.
other wise try takeing the batteries out whenever you are done and see how long they last that way. then you will know if it is a short if they last a long time.
Try these links:
http://www-user.tu-chemnitz.de/~choc/minolta/mirror/ca.konicaminolta.com/support/americas/software/dimage-series/dimage-viewer/software_drivers/index.html
http://kmbs.konicaminolta.us/content/support/supporthome.html
This is an update. Sony is now handling repairs for the defective Sony CCD issue. Sony will fix your Minolta camera for free (with free shipping) regardless of warranty. You need to do this before March 31, 2008 so for others who have this problem get going! See this link: http://esupport.sony.com/US/perl/news-item.pl?template_id=1&news_id=131#
The Dimage models that Sony is accepting for the recall repair are:
Dimage 7HI, 7I, A1, Xi, F300, XT, X20, S414.
We have received a number of inquiries regarding the usage of Konica Minolta digital cameras with non-genuine or counterfeit Konica Minolta lithium-ion batteries.
Please be advised that genuine Konica Minolta lithium-ion batteries are equipped with security system to prevent the camera from damages. It has been reported that some counterfeit batteries are NOT equipped with a security system. The use of such batteries will cause damage to your Konica Minolta digital camera and may cause fire.
Further, every Konica Minolta digital camera has been designed to fulfill its nominal value in performance with a corresponding genuine Konica Minolta lithium-ion battery.
For safety and optimum performance, we recommend that you only use genuine Konica Minolta lithium-ion batteries with Konica Minolta digital cameras. Genuine Konica Minolta lithium-ion batteries will include the Konica Minolta model # (NP-200, NP-400, etc) and are only available through authorized Konica Minolta dealers and the Konica Minolta on-line store.
Please note that Konica Minolta is not responsible for damages or troubles caused by the use of lithium batteries which are not specified in the instruction manuals or not produced/distributed by Konica Minolta Camera Inc.
(Updated 01/29/04)
Genuine Konica Minolta lithium-ion batteries are listed below:
Konica Lithium-ion Battery DR-LB4 for Konica Digital Revio KD-510Z/410Z/500Z/400Z/310Z
Minolta Lithium-ion Battery NP-200 for Minolta DiMAGE Xt/Xi/X
Minolta Lithium-ion Battery NP-400 for Minolta DiMAGE A1
Minolta Lithium-ion Battery NP-600 for Minolta DiMAGE G400
Minolta Lithium-ion Battery NP-500 for Minolta DiMAGE G500
Minolta External High-Power Battery EBP-100* is available for the following models:
Minolta DiMAGE A1/Z1/7Hi/7i/7/5/S414/S404/S304
* EBP-100 is consisted of 2pcs. Lithium-ion Battery NP-100, 1pc. Battery Holder BH-100, and 1pc. Lithium-ion Battery Charger BC-100
Yes, the DiMAGE 7 is PIM-enabled. The camera records necessary information as it stores every image captured, and passes printing option information to a PIM-enabled printer to create optimum results. The PIM-enabled printers process the image automatically for excellent print quality.
No, Minolta cannot guarantee compatibility of the DiMAGE 7 with a third party USB cable. The USB-1000 Cable supplied with the camera should be used exclusively.
The DiMAGE 7 Optional Enhancement Upgrade software is available for purchase through Konica Minolta's Online Store. It can also be installed by Konica Minolta's NJ Repair Facility.
Please visit the Konica Minolta on-line store using the link on the lefthand side of our homepage.
(Updated 01/29/04)
For further assistance concerning Konica Minolta products, please contact Konica Minolta technical support by phone or Interactive Q&A or visit our website at http://www.konicaminolta.us
Thank you for your understanding and cooperation in this matter. We look forward to your continued support for Konica Minolta products.
Attached
Thanks
Avo
