Unit stuck in safeguard mode, remove and reattach battery. I have tried this several times waiting different length of time. I also tried to use the power source without the battery and can not get past this message. Strangely it does work in memory mode.
Have the same problem message 01 safe move keeps appearing.What should I do ?
I have the same fault. Cassette will not eject or play. Error message is 01 sometimes 02.
I have the same problem, it said Unit in Safeguard mode eject and insert tape though with a little 03 at the bottom.
I HAVE THIS PROBLEM ALSO
i cant get safe mode off or remove my tape
stuck in safe mode with the error 03
Stuck in safe mode
I am getting the same message but also getting about 1/4" lines through video sometimes when it DOES play in the viewer.
Wife dropped the unit, stuck in safe mode.
dropped camera. Stuck in safeguard mode. Keep ejecting and reinstering tape to no result
I have not used by DV camcorder for some time. It is showing that the recorder is stuck in safe mode . Plz remove & reinstate battery. No change if i do this. Kindly help
unit stuck in safeguard mode, remove and reattach battery. I have tried this several times .Cassette will not eject or play
I have the same fault. Cassette will not eject or play. Error message 01 Unit stuck in safeguard mode
