Sylvania LC225SSX LCD TV Logo
Posted on Mar 26, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Flat panel TV shows a bright pinpoint of light in dark scenes
When my new Sylvania flat panel TV shows a dark scene, I can see a tiny pinpoint of white light in one spot. It is always there. Is this a sign of future larger problem?
Anonymous
Level 3:
  • Master 644 Answers
  • Posted on Mar 26, 2010
Anonymous
Master
Level 3:
Answers
644
Questions
Helped
217540
Points
1886
No its not much to worry about its just a dead pixel. Most LCD TV's have them, some can be more noticable than others. Even though it can be anoying you TV is'nt going to fail because of it.
Anonymous
Level 2:
  • Expert 308 Answers
Anonymous
Expert
Level 2:
Answers
308
Questions
0
Helped
134819
Points
814
Maybe or maybe not. It is a pixel that is stuck 'on' all the time. Not a warranty claim item as a few bad pixels are allowed.....
It does not spread, but that is not to say that another pixel somewhere else on the screen will not go bad.
Why is my Sanyo vizon sdtv picturetoo dark in the dark scenes
Back light 11..Contrast 72..Sharpness 20..Brightness 44..Colour 50..Tint 50.
2helpful
I have a vizio Vt470m....the picture has always been perfect. All of a sudden when picture shows scenes with very little light (dark scenes like at night, space, low light) the black color almost look
Either the TCON board or the LCD panel has failed. Start by replacing the TCON board. If the problem persists, the panel is bad and the cost to replace it would be too high.
Voire 46" plasma tv- best color settings, to much white
The proper way to set flat screen tv's is opposite of old school CRT tv. First, find a movie with dark scenes and pause on a really dark part. Now set brightness only high enough to see some detail - no more. then go to a really bright scene and set contrast just high enough for good brightness. You may need to go back and forth a few times to get good setting.
4helpful
Brand new 47" "Edge Lit" LED, model MV4(Cant
I believe there may be another setting, it has to do with auto contrast which can make the TV seems to have high contrast ratio but sometime it does not work right, espically on the scene with dark sky with stars, someitme it will will reduce the brightness to make black real black and you can loger see the stars in the scene. I forget the name of this setting, it may be in the user manual. Do you see that in TV HD mode in other movies with a lot of dark scenes?
Red rash that shows through in dark scenes. Can't
Might cause magnatic field,form.Try unplug,replug the tv an hour,move it couple inches to the left or right might help.
Magnavox 42"
You are correct=====Return it ! It's new, you should not have to have it repaired this soon.
3helpful
The TV brightness dims when the we get a dim scene
This is probably normal and called "Dynamic Contrast". Maybe this company has some other proprietary naming.
Basically, the Backlight (LCD) or Bulb (Projection) will be dimmed during dark scenes to allow the TV to make a deeper black.
Picteru darkens to much
There are two settings within you menu that controls the brightness of what is going on. OPC, and Active contrast. Turn both of those off and you should have some luck.
Brightness difficulty
I had the same problem and so went into the menu and selected brightness and increased the number, and my dark pictures were much better.
Top Sylvania Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
