Nikon D60 Digital Camera Logo
Posted on Mar 26, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
No flash and slow shutter - Nikon D60 Digital Camera
Anonymous
Level 3:
Genius:
  • Master 1,035 Answers
  • Posted on Mar 26, 2010
Anonymous
Master
Level 3:
Genius:
Answers
1035
Questions
0
Helped
400155
Points
3026
Posible issue on the camera settings.
You can check this site for the Troubleshooting and manuals for you camera.
http://esupport.sony.com/US/perl/model-documents.pl?mdl=DSCD700&region_id=1
for the manual it is on the PDF file and it will ask you to download that.
on the manual you can look for default settings and it will set everything to default.
My D60 only when I use the flash I get an error message job nr
Job NR is usually associated with the camera's processing time during very slow shutters. If you wait long enough it will show you the image you've taken but because the shutter is very slow, the image will be blurry and unrecognizable. On manual mode or Shutter speed priority change your shutter speed to at least .125 of a second. That should fix the problem.
1helpful
Pentax K110d flash trigger problem, I have 2 flash trigger strobes set up and a flash on the hot shoe of the camera, but with shutter release the trigger strobe lights fire but do not show in the pic, only...
Your camera uses a PTTL flash system. That means the flash on the camera fires a "pre-flash" to set the exposure and then the main flash. Your flash trigger strobes are reacting to the pre-flash and firing before the shutter activates. This all happens in a millisecond.
Don't know what buttons on back of camera are for.
Besides the auto-flash mode, you can select fill flash, flash off, self-timer, and nighttime-view with or without flash.
Press the MODE-SELECTOR BUTTON until the desired indicator appears on the LCD PANEL.
c3015.gif Fill flash and flash off modes remain selected after you take the picture. To cancel the selection, press the mode-selection button or close and reopen the lens cover/flash to return to the auto-flash mode.
Fill flash
c3014.gif When bright light indoors or outdoors comes from behind the subject (backlighting), dark shadows (especially on faces) may occur. Use fill flash to lighten these shadows.
  1. Open the LENS COVER/FLASH to raise the flash and to turn the camera ON.
  2. Press the MODE-SELECTOR BUTTON repeatedly until the FILL-FLASH INDICATOR appears on the LCD PANEL.
  3. Frame your subject within the VIEWFINDER EYEPIECE.
  4. Partially depress the SHUTTER BUTTON. When the FLASH/CAMERA-READY LAMP turns off and the fill-flash indicator on the LCD panel stops blinking, fully depress the shutter button to take the picture.
Flash off
c3013.gif When you do not want to use the flash, especially indoors where flash is prohibited, such as in theaters and museums, or when you want to take twilight scenes or distant subjects that are beyond the flash range, or capture the ambiance of existing light, use the flash-off feature. Use a tripod or place the camera on another firm support, and use high-speed film because the shutter speed in these situations will most likely be slow.
  2. Press the MODE-SELECTOR BUTTON repeatedly until the FLASH-OFF INDICATOR appears on the LCD PANEL.
  4. Press the SHUTTER BUTTON to take the picture.
Self-timer with auto flash
c3016.gif Use this feature to include yourself in pictures.
  1. Use the TRIPOD SOCKET to attach the camera to a tripod or place it on another firm support.
  2. Open the LENS COVER/FLASH to raise the flash and to turn the camera ON.
  3. Press the MODE-SELECTOR BUTTON repeatedly until the SELF-TIMER INDICATOR appears on the LCD PANEL.
  4. Frame your subject within the VIEWFINDER EYEPIECE.
  5. Press the SHUTTER BUTTON. The SELF-TIMER LAMP will glow and then blink during the last three seconds of countdown.
    • To cancel the self-timer selection before the shutter releases, close the flash.
    • The self-timer automatically turns off after the shutter releases.
Night-view with flash
c3012.gif In this mode, the camera balances the flash and existing light exposure so you can take beautiful pictures of people at sunset or at night. Use a tripod or place the camera on another firm support, and use high-speed film because the shutter speed at night will most likely be slow.
  2. Press the MODE-SELECTOR BUTTON repeatedly until the NIGHTTIME-VIEW INDICATOR with flash appears on the LCD PANEL.
  3. Frame your picture in the VIEWFINDER EYEPIECE.
  4. Press and hold the SHUTTER BUTTON for 12 seconds without lifting your finger. Note: If you remove your finger from the shutter button before 12 seconds, the shutter will time out immediately.
  5. After 12 seconds, release the shutter button to take the picture.
Night-view without flas
c3011.gif In this mode, you can capture the natural existing light of city-night scenes or fireworks at night. Use a tripod or place the camera on another firm support, and use high-speed film because the shutter speed at night will most likely be slow.
  2. Press the MODE-SELECTOR BUTTON repeatedly until the NIGHTTIME-VIEW INDICATOR without flash appears on the LCD PANEL.
2answers
Canon G10 flash recharge very slow at 10sec. Any way to make it faster?
Has it always been this slow? Are your batteries fresh and charged?
2answers
D300 long shutter delay
are you using mirror lock-up or live-view feature?
Blurred images
This is mainly due to the slow shutter speed selected by your CAM. in low light situations the cam chooses a slow shutter speed to expose the image adequately. Any shakes that may have caused during the shutter operation will cause the funny images.
use tripod or other kind of support to your camera while shootiing in low light (indoors) without flash.
Indoor flash images are blurry
It is possible you have the Flash Mode set to one of the Slow Sync modes (lighting bolt with the word Slow). Slow synchronization flash sets a slow shutter speed for the background exposure and fires the flash for the subject exposure. Since the shutter speed is slow, your subject should be still and the camera should be on a tripod otherwise blur can result. Since this mode should only be used when the above conditions can be met, you should use the FILL-IN FLASH (single lighting bolt symbol) mode for most situations that require a flash for correct exposure. Repeatedly pressing the FLASH MODE button will cycle through the various flash mode settings.
Flash images are blurry
Images are blurry
Top Nikon Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Nikon Camera Expert? Answer questions, earn points and help others
